Tach/Turn signal conversion doesn't work, Got it working - different than the Up 'n Fixin diagram, though |
sfrenck |
Jul 28 2013, 12:01 PM
Member Group: Members Posts: 492 Joined: 28-February 10 From: Wilmington, DE Member No.: 11,411 Region Association: MidAtlantic Region |
Used this information to install my 73 Tach into my 74 car:
You would add two wires from the emergency flasher switch to the bulbs you will use (green/black and white/ black). These are the same wires and colors leading out to the turn signal bulbs at the four corners of the car. You will modify the existing blue/white wire to extend to the other side of BOTH bulbs. The blue/white wire terminates at the flasher relay itself. Weird thing is when all the wires are connected to the hazard switch, neither indicator works for flasher or turn signal. If I unplug the L or R from the hazard switch, both turn signal indicators work as they are supposed to and one of them lights up with the hazard (whichever one I didn't unplug)? I've already switched out the hazard switch. (IMG:style_emoticons/default/WTF.gif) Newer Update: All works if I detach the blue wire w/ white stripe from the turn indicator bulbs and instead install a ground to them. Guess I'm going with this solution rather than the diagram above indicating I need the two blue/white stripe (or, as indicated below, take the blue/white wire off of the flasher at terminal K and connect the wire to ground). |
Lo-Fi Version | Time is now: 19th May 2024 - 07:46 AM |
