> Pedal board template?
jeff88ix
post Aug 4 2013, 07:55 PM
Anyone have a template for the pedal board? I don't have the original and would like to make one. AutoCad, .dxf, or ? pretty sure I can use most file formats.
Thanks
Jeff
chad newton
post Aug 4 2013, 08:07 PM
Like a dumb a$$ I threw mine away. I probably won't install one now.
Mark Henry
post Aug 5 2013, 08:05 AM
that's what I do!
QUOTE(chad newton @ Aug 4 2013, 10:07 PM) *
I wouldn't do that as the board has a stop that limits the clutch (IIRC) return travel. I can't remember the details, but I remember not using one causes stress on a component that can lead to a failure.
lsintampa
post Aug 5 2013, 08:16 AM
QUOTE(Mark Henry @ Aug 5 2013, 10:05 AM) *
Yeah, what happens is the cable (if not stopped) can be stretched and over time will brake. Same can happen with the throttle cable if you have it stretching at full throttle.
jeff88ix   Pedal board template?   Aug 4 2013, 07:55 PM
ConeDodger   Anyone have a template for the pedal board? I don...   Aug 4 2013, 07:58 PM
stugray   wondering if I could scan one...... I have a pris...   Aug 4 2013, 08:03 PM
chad newton   Like a dumb a$$ I threw mine away. I pr...   Aug 4 2013, 08:07 PM
Mark Henry   Like a dumb a$$ I threw mine away. I p...   Aug 5 2013, 08:05 AM
lsintampa   Like a dumb a$$ I threw mine away. I ...   Aug 5 2013, 08:16 AM
Cap'n Krusty   Like a dumb a$$ I threw mine away. I ...   Aug 5 2013, 08:17 AM
stugray   My scans didn't look too good. out of focus ...   Aug 4 2013, 08:19 PM
jeff88ix   Stu, I was just planning on making a wood one, I ...   Aug 4 2013, 08:24 PM
speed metal army   914 rubber has em.   Aug 4 2013, 10:21 PM
Bartlett 914   Throttle stop is also important. You can damage th...   Aug 5 2013, 10:19 AM
Mikey914   Got them if you want. I even put it on sale for yo...   Aug 6 2013, 06:44 PM
solex   I cut mine out of aluminum covered plywood the sam...   Aug 7 2013, 01:29 PM
Mikey914   I cut mine out of aluminum covered plywood the sa...   Aug 9 2013, 08:53 AM
solex   I cut mine out of aluminum covered plywood the s...   Aug 9 2013, 01:53 PM
LotusJoe   Like this one. I had it cut at my local hydro-cutt...   Aug 9 2013, 10:01 AM
7TPorsh   Like this one. I had it cut at my local hydro-cut...   Aug 9 2013, 10:20 AM
jimkelly   just buy it http://shop.914rubber.com/Plywood-flo...   Aug 9 2013, 10:06 AM
LotusJoe   Sold all of my last batch. I might consider anothe...   Aug 9 2013, 11:12 AM
Wegeng_Haus   Anyone have a template for the pedal board? I don...   Aug 9 2013, 12:01 PM
jeff88ix   Ok, I have found an original to copy, Thanks Van...   Aug 9 2013, 04:26 PM
- Lo-Fi Version Time is now: 2nd April 2026 - 05:09 PM
