jeff88ix
Aug 4 2013, 07:55 PM
Anyone have a template for the pedal board? I don't have the original and would like to make one. AutoCad, .dxf, or ? pretty sure I can use most file formats.
Thanks
Jeff
ConeDodger
Aug 4 2013, 07:58 PM
QUOTE(jeff88ix @ Aug 4 2013, 05:55 PM)
Thanks
Jeff
I think 914Rubber sells them... Peddle boards I mean...
stugray
Aug 4 2013, 08:03 PM
wondering if I could scan one......
I have a pristine blank.
Stu
chad newton
Aug 4 2013, 08:07 PM
Like a dumb a$$ I threw mine away. I probably won't install one now.
stugray
Aug 4 2013, 08:19 PM
My scans didn't look too good. out of focus & cant get the whole thing.
how about Hires photos?
Can you convert them?
If you could make two nice reproductions from a superior material, I would send you my perfect board as a master.
Stu
jeff88ix
Aug 4 2013, 08:24 PM
Stu,
I was just planning on making a wood one, I think I just need a good tracing, something full scale. I could then make an AutoCad file that would be available to others.
Thanks
Jeff
speed metal army
Aug 4 2013, 10:21 PM
914 rubber has em.
Mark Henry
Aug 5 2013, 08:05 AM
QUOTE(chad newton @ Aug 4 2013, 10:07 PM)
I wouldn't do that as the board has a stop that limits the clutch (IIRC) return travel. I can't remember the details, but I remember not using one causes stress on a component that can lead to a failure.
lsintampa
Aug 5 2013, 08:16 AM
QUOTE(Mark Henry @ Aug 5 2013, 10:05 AM)
Yeah, what happens is the cable (if not stopped) can be stretched and over time will brake. Same can happen with the throttle cable if you have it stretching at full throttle.
Cap'n Krusty
Aug 5 2013, 08:17 AM
QUOTE(Mark Henry @ Aug 5 2013, 07:05 AM)
Thet component would be the clutch cover, AKA pressure plate.
The Cap'n
Bartlett 914
Aug 5 2013, 10:19 AM
Throttle stop is also important. You can damage the throttle body, break the cable or have it pull out of the clamp.
Mikey914
Aug 6 2013, 06:44 PM
Got them if you want. I even put it on sale for you if you need it.
http://shop.914rubber.com/Plywood-floor-bo...nly-914FB-P.htm
solex
Aug 7 2013, 01:29 PM
I cut mine out of aluminum covered plywood the same thickness as the original except much stronger
Mikey914
Aug 9 2013, 08:53 AM
QUOTE(solex @ Aug 7 2013, 12:29 PM)
Why not just cut it out of aluminum?
LotusJoe
Aug 9 2013, 10:01 AM
Like this one. I had it cut at my local hydro-cutter
jimkelly
Aug 9 2013, 10:06 AM
7TPorsh
Aug 9 2013, 10:20 AM
QUOTE(LotusJoe @ Aug 9 2013, 09:01 AM)
Click to view attachmentoooh...can I get on of these?
LotusJoe
Aug 9 2013, 11:12 AM
Sold all of my last batch. I might consider another run here soon.
Wegeng_Haus
Aug 9 2013, 12:01 PM
QUOTE(jeff88ix @ Aug 4 2013, 08:55 PM)
Thanks
Jeff
have the template for the passenger side floorboard, that I designed.
solex
Aug 9 2013, 01:53 PM
QUOTE(Mikey914 @ Aug 9 2013, 10:53 AM)
That's what I had lying around
jeff88ix
Aug 9 2013, 04:26 PM
Ok, I have found an original to copy, Thanks Van!
I plan on making an AutoCAD drawing of it which I will make available to others when done.
Thanks everyone!
Jeff
