Pedal board template? |
jeff88ix |
Aug 4 2013, 07:55 PM
Newbie Group: Members Posts: 3 Joined: 19-December 12 From: Wisconsin Member No.: 15,270 Region Association: Upper MidWest |
Anyone have a template for the pedal board? I don't have the original and would like to make one. AutoCad, .dxf, or ? pretty sure I can use most file formats.
Thanks Jeff |
ConeDodger |
Aug 4 2013, 07:58 PM
Apex killer! Group: Members Posts: 23,591 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
stugray |
Aug 4 2013, 08:03 PM
wondering if I could scan one......
I have a pristine blank. Stu |
chad newton |
Aug 4 2013, 08:07 PM
Member Group: Members Posts: 110 Joined: 26-August 11 From: behind the red curtain Member No.: 13,491 Region Association: None |
Like a dumb a$$ I threw mine away. I probably won't install one now.
stugray |
Aug 4 2013, 08:19 PM
My scans didn't look too good. out of focus & cant get the whole thing.
how about Hires photos? Can you convert them? If you could make two nice reproductions from a superior material, I would send you my perfect board as a master. Stu |
jeff88ix |
Aug 4 2013, 08:24 PM
Stu,
I was just planning on making a wood one, I think I just need a good tracing, something full scale. I could then make an AutoCad file that would be available to others. Thanks Jeff |
speed metal army |
Aug 4 2013, 10:21 PM
Waiting for the rain to stop... Group: Members Posts: 1,068 Joined: 4-September 10 From: PNW Member No.: 12,137 Region Association: Canada |
914 rubber has em.
Mark Henry |
Aug 5 2013, 08:05 AM
Like a dumb a$$ I threw mine away. I probably won't install one now. I wouldn't do that as the board has a stop that limits the clutch (IIRC) return travel. I can't remember the details, but I remember not using one causes stress on a component that can lead to a failure. |
lsintampa |
Aug 5 2013, 08:16 AM
Senior Member Group: Members Posts: 520 Joined: 28-January 13 From: Tampa, FL Member No.: 15,441 Region Association: South East States |
Like a dumb a$$ I threw mine away. I probably won't install one now. I wouldn't do that as the board has a stop that limits the clutch (IIRC) return travel. I can't remember the details, but I remember not using one causes stress on a component that can lead to a failure. Yeah, what happens is the cable (if not stopped) can be stretched and over time will brake. Same can happen with the throttle cable if you have it stretching at full throttle. |
Cap'n Krusty |
Aug 5 2013, 08:17 AM
Like a dumb a$$ I threw mine away. I probably won't install one now. I wouldn't do that as the board has a stop that limits the clutch (IIRC) return travel. I can't remember the details, but I remember not using one causes stress on a component that can lead to a failure. Thet component would be the clutch cover, AKA pressure plate. The Cap'n |
Bartlett 914 |
Aug 5 2013, 10:19 AM
Throttle stop is also important. You can damage the throttle body, break the cable or have it pull out of the clamp.
Mikey914 |
Aug 6 2013, 06:44 PM
The rubber man Group: Members Posts: 12,670 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Got them if you want. I even put it on sale for you if you need it.
http://shop.914rubber.com/Plywood-floor-bo...nly-914FB-P.htm |
solex |
Aug 7 2013, 01:29 PM
Senior Member Group: Members Posts: 789 Joined: 12-January 05 From: Long Island, NY Member No.: 3,439 Region Association: North East States |
I cut mine out of aluminum covered plywood the same thickness as the original except much stronger
Mikey914 |
Aug 9 2013, 08:53 AM
LotusJoe |
Aug 9 2013, 10:01 AM
Europa Twink Driver Group: Members Posts: 406 Joined: 30-November 09 From: Southern California Member No.: 11,085 Region Association: Southern California |
Like this one. I had it cut at my local hydro-cutter
jimkelly |
Aug 9 2013, 10:06 AM
Delaware USA Group: Members Posts: 4,969 Joined: 5-August 04 From: Delaware, USA Member No.: 2,460 Region Association: MidAtlantic Region |
7TPorsh |
Aug 9 2013, 10:20 AM
LotusJoe |
Aug 9 2013, 11:12 AM
Sold all of my last batch. I might consider another run here soon.
Wegeng_Haus |
Aug 9 2013, 12:01 PM
Newbie Group: Members Posts: 38 Joined: 10-December 11 From: Champaign Illinois Member No.: 13,881 Region Association: Upper MidWest |
Anyone have a template for the pedal board? I don't have the original and would like to make one. AutoCad, .dxf, or ? pretty sure I can use most file formats. Thanks Jeff have the template for the passenger side floorboard, that I designed. Attached thumbnail(s) |
solex |
Aug 9 2013, 01:53 PM
Lo-Fi Version | Time is now: 19th May 2024 - 09:43 AM |
