| jeff88ix |
Aug 4 2013, 07:55 PM
Newbie ![]() Group: Members Posts: 3 Joined: 19-December 12 From: Wisconsin Member No.: 15,270 Region Association: Upper MidWest |
Anyone have a template for the pedal board? I don't have the original and would like to make one. AutoCad, .dxf, or ? pretty sure I can use most file formats.
Thanks Jeff |
| chad newton |
Aug 4 2013, 08:07 PM
Member ![]() ![]() Group: Members Posts: 110 Joined: 26-August 11 From: behind the red curtain Member No.: 13,491 Region Association: None |
Like a dumb a$$ I threw mine away. I probably won't install one now.
| Mark Henry |
Aug 5 2013, 08:05 AM
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada |
Like a dumb a$$ I threw mine away. I probably won't install one now. I wouldn't do that as the board has a stop that limits the clutch (IIRC) return travel. I can't remember the details, but I remember not using one causes stress on a component that can lead to a failure. |
| Cap'n Krusty |
Aug 5 2013, 08:17 AM
Cap'n Krusty ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,794 Joined: 24-June 04 From: Santa Maria, CA Member No.: 2,246 Region Association: Central California |
Like a dumb a$$ I threw mine away. I probably won't install one now. I wouldn't do that as the board has a stop that limits the clutch (IIRC) return travel. I can't remember the details, but I remember not using one causes stress on a component that can lead to a failure. Thet component would be the clutch cover, AKA pressure plate. The Cap'n |
jeff88ix Pedal board template? Aug 4 2013, 07:55 PM
ConeDodger
Anyone have a template for the pedal board? I don... Aug 4 2013, 07:58 PM
stugray wondering if I could scan one......
I have a pris... Aug 4 2013, 08:03 PM
lsintampa
Like a dumb a$$ I threw mine away. I ... Aug 5 2013, 08:16 AM
stugray My scans didn't look too good. out of focus ... Aug 4 2013, 08:19 PM
jeff88ix Stu,
I was just planning on making a wood one, I ... Aug 4 2013, 08:24 PM
speed metal army 914 rubber has em. Aug 4 2013, 10:21 PM
Bartlett 914 Throttle stop is also important. You can damage th... Aug 5 2013, 10:19 AM
Mikey914 Got them if you want. I even put it on sale for yo... Aug 6 2013, 06:44 PM
solex I cut mine out of aluminum covered plywood the sam... Aug 7 2013, 01:29 PM
Mikey914
I cut mine out of aluminum covered plywood the sa... Aug 9 2013, 08:53 AM
solex
I cut mine out of aluminum covered plywood the s... Aug 9 2013, 01:53 PM
LotusJoe Like this one. I had it cut at my local hydro-cutt... Aug 9 2013, 10:01 AM
7TPorsh
Like this one. I had it cut at my local hydro-cut... Aug 9 2013, 10:20 AM
jimkelly just buy it
http://shop.914rubber.com/Plywood-flo... Aug 9 2013, 10:06 AM
LotusJoe Sold all of my last batch. I might consider anothe... Aug 9 2013, 11:12 AM
Wegeng_Haus
Anyone have a template for the pedal board? I don... Aug 9 2013, 12:01 PM
jeff88ix Ok, I have found an original to copy, Thanks Van... Aug 9 2013, 04:26 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 06:43 PM |
