Oil tank/ cooler plumbing help |
chad newton |
Aug 6 2013, 11:41 PM
Member Group: Members Posts: 110 Joined: 26-August 11 From: behind the red curtain Member No.: 13,491 Region Association: None |
Ok, I am going to end up with my tank in the back in the battery box position and run a regular cooler in the front. I have no idea how to plumb it. Can I run aluminum hard line or should I go with some type of hose? Where do you run your cooler from, oil tank or engine? Is there any pressure in this system at all? Even a good link would be awesome that I could do my research on. Thanks again.
chad newton |
Aug 7 2013, 01:40 PM
Dose anyone see a problem with running aluminum hard line? I have used it for fuel lines in the past. Stays ridged, and bends pretty much everywhere you want it, plus it may help with heat distribution.
Lo-Fi Version | Time is now: 11th June 2024 - 10:22 AM |
