Oil tank/ cooler plumbing help |
chad newton |
Aug 6 2013, 11:41 PM
Member Group: Members Posts: 110 Joined: 26-August 11 From: behind the red curtain Member No.: 13,491 Region Association: None |
Ok, I am going to end up with my tank in the back in the battery box position and run a regular cooler in the front. I have no idea how to plumb it. Can I run aluminum hard line or should I go with some type of hose? Where do you run your cooler from, oil tank or engine? Is there any pressure in this system at all? Even a good link would be awesome that I could do my research on. Thanks again.
stugray |
Aug 7 2013, 02:14 PM
Advanced Member Group: Members Posts: 3,825 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None |
QUOTE Dose anyone see a problem with running aluminum hard line? I was considering running it from the rear remote oil filter bracket to the front trunk and back again. Then Aramid braided hose everywhere else. You can get it at McMastercarr cheap and in rolls. It can be flared, but at 12AN (3/4") sizes, the flare tool is expensive. Stu |
Lo-Fi Version | Time is now: 11th June 2024 - 10:16 AM |
