> Engine Knocking after rebuild
LCOX
post Aug 6 2013, 07:31 PM
I've got a sick feeling I'm going to have to take my 1.8 engine out and completely apart again after rebuilding it.
Cranked it up for the first time after rebuilding it(all new bearings, new rings, head work and gasket set).
The engine has a knock fairly loud at idle but when the engine rpm's are around 1500 it starts to quieten down and at 2000 rpms the knock goes away completely only to come back at idle when rpms are around 800-900. Other than that the engine appears to run very smooth.
Where to I start here. L
Dave_Darling
post Aug 9 2013, 12:25 PM
914 Idiot
You can pull the cylinders off, then the pistons, and work around the rods to reach in and remove the conrod bolts. You reach in through the spigots where the pistons go.
It doesn't look like much fun, but it's probably less work than tearing the entire thing down. But you won't get to check as many things.
--DD
worn
post Aug 9 2013, 02:11 PM
QUOTE(Dave_Darling @ Aug 9 2013, 10:25 AM) *
--DD
Exactly what I meant to say. Thanks Dave.
LCOX   Engine Knocking after rebuild   Aug 6 2013, 07:31 PM
bulitt   Pull the coil to distributor wire. Then crank it. ...   Aug 6 2013, 07:43 PM
sean_v8_914   what pistons did you use? might be skirt slap. doe...   Aug 6 2013, 08:09 PM
Bartlett 914   what pistons did you use? might be skirt slap. do...   Aug 8 2013, 02:28 PM
aircooledtechguy   Before assuming the worst, take a methodical look ...   Aug 6 2013, 10:07 PM
mrbubblehead   you could pull the spark plug wires one at a time ...   Aug 6 2013, 10:27 PM
LCOX   Update: I followed Mr Bubbleheads advice and pull...   Aug 8 2013, 01:40 PM
mrbubblehead   Update: I followed Mr Bubbleheads advice and pul...   Aug 8 2013, 08:50 PM
larss   and couldn't hear or fill a knock. i was hop...   Aug 9 2013, 04:19 AM
malcolm2   So what is it about a rod that will make the knock...   Aug 9 2013, 07:49 AM
Vacca Rabite   Are there spacers under the valve rockers? If so ...   Aug 8 2013, 06:03 PM
stugray   The large rod ends are just about the only simpl...   Aug 9 2013, 09:02 AM
sean_v8_914   aircooledtechguy said something very important: al...   Aug 9 2013, 09:27 AM
LCOX   If it is a rod can't I take it off the crank w...   Aug 9 2013, 09:56 AM
worn   If it is a rod can't I take it off the crank ...   Aug 9 2013, 11:55 AM
mrbubblehead   If it is a rod can't I take it off the crank ...   Aug 9 2013, 05:22 PM
LCOX   I just checked the valve adjustment on #3 and it...   Aug 9 2013, 10:40 AM
The Cabinetmaker   Worn, please splain the "no, you can" th...   Aug 9 2013, 12:19 PM
Dave_Darling   You can pull the cylinders off, then the pistons, ...   Aug 9 2013, 12:25 PM
worn   You can pull the cylinders off, then the pistons,...   Aug 9 2013, 02:11 PM
stugray   Whenever I need to pull the cylinders, I pull them...   Aug 9 2013, 01:59 PM
worn   Whenever I need to pull the cylinders, I pull the...   Aug 9 2013, 03:08 PM
Maltese Falcon   See if you installed a con rod flipped in the wron...   Aug 10 2013, 12:50 AM
stugray   And how can you tell? I did not install mine in ...   Aug 10 2013, 10:40 AM
The Cabinetmaker   Stock rods have #s stamped on the rod and cap. The...   Aug 10 2013, 10:55 AM
stugray   I got that part and made sure to keep the caps o...   Aug 10 2013, 10:56 AM
r_towle   I got that part and made sure to keep the caps ...   Aug 10 2013, 04:50 PM
euro911   I rebuilt my first VW engine (40-horse) in 1970 an...   Aug 10 2013, 11:07 AM
Racer Chris   T4 rods are straight but stock pistons have a pin ...   Aug 11 2013, 07:43 AM
LCOX   Ok Everybody here is what I know. I just lowered ...   Aug 19 2013, 06:40 PM
r_towle   Numbers face the sky, as in UP.   Aug 19 2013, 06:49 PM
r_towle   End play shims done properly? Oil pump new? Type 4...   Aug 19 2013, 06:51 PM
mrbubblehead   dont the rods a a tab or tange on one side of the ...   Aug 19 2013, 07:06 PM
euro911   If you're torn down this far, probably a good ...   Aug 19 2013, 07:44 PM
stugray   The way I read what Chris said above is that there...   Aug 19 2013, 09:18 PM
Racer Chris   The way I read what Chris said above is that ther...   Aug 19 2013, 09:35 PM
LCOX   I guess I'm a little confused now. Am I gettin...   Aug 20 2013, 08:01 AM
Racer Chris   I guess I'm a little confused now. Am I getti...   Aug 20 2013, 11:42 AM
LCOX   Update. Chris I pulled #4 p/c and rod off and comp...   Aug 20 2013, 11:50 AM
stugray   So when you checked the deck height you didnt noti...   Aug 20 2013, 11:57 AM
LCOX   stu. I measured the rod end to end and the shorter...   Aug 20 2013, 12:17 PM
LCOX   I checked closely and don't see any evidence o...   Aug 20 2013, 12:27 PM
malcolm2   How are you measuring rod length? I would expect ...   Aug 20 2013, 01:02 PM
euro911   Pull the rods, measure them, and weigh them all to...   Aug 20 2013, 01:27 PM
LCOX   Mark. I've looked closer at both rods. It ap...   Aug 20 2013, 05:23 PM
stugray   That makes sense. I didnt think you could put in...   Aug 20 2013, 06:14 PM
LCOX   stu. so they weigh both sides of each rod individu...   Aug 20 2013, 07:12 PM
Racer Chris   Could this throw off the balance of the rod and c...   Aug 21 2013, 10:41 AM
LCOX   Here is a picture of the rods. #3 is on the right...   Aug 21 2013, 10:01 AM
stugray   If you are really anal about your balancing: http...   Aug 21 2013, 11:23 AM
euro911   I wouldn't consider it anal ... it's the r...   Aug 21 2013, 12:38 PM
- Lo-Fi Version Time is now: 2nd April 2026 - 06:14 PM
