More surprises found in my engine!, Someone put an extra 2mm in there |
Demick |
Jul 16 2004, 08:48 AM
Ernie made me do it! Group: Benefactors Posts: 2,312 Joined: 6-February 03 From: Pleasanton, CA Member No.: 257 |
I've found a bunch of surprises while tearing down my engine, but none as big as what I found last night. I'm not even sure what prompted me to measure the cylinder diameter, but when I did I got quite a surprise. 96mm P&C's which means I've had a 2.056 motor all this time and never knew it! I feel bad that I've been running in stock engine classes for autocross for all these years - but then again, most of the people running probably don't know for sure the internals of their motors either. Mine was rebuilt over 20 years ago (that's 5 owners ago!).
So this really screws up my rebuilding plans. I had planned to do a stock rebuild using the higher compression euro pistons. I had thought that this rebuild would give me about 10hp over what I had before (5hp for the euro pistons, and another 5hp due to a fresh engine). But now I'm thinking maybe I should build the engine a little more agressively. Continue with 96mm pistons, but go higher on the compression like somewhere around 8.5:1 (my engine had dished pistons and probably a fairly stock compression ratio since I always ran regular gas with no problems). Maybe a little head work to get the engine to breathe a little better...... Hmmm..... Basically build the engine to the limit of what I can run with the stock d-jet F.I. Decisions, Decisions. Luckily I haven't bought any hard parts yet..... Demick Attached image(s) |
Lo-Fi Version | Time is now: 17th June 2024 - 07:28 AM |
