| 914itis |
Aug 12 2013, 11:01 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,892 Joined: 9-October 10 From: New York City Member No.: 12,256 Region Association: North East States |
Will this fit a 914-6 at the stock location?
| shoguneagle |
Aug 13 2013, 08:49 AM
shoguneagle ![]() ![]() ![]() Group: Members Posts: 1,180 Joined: 3-January 03 From: CA, OR, AZ (CAZOR); New Mexico Member No.: 84 Region Association: Northern California |
Slits has it right. I do have a 911 tank and it is placed in the rear trunk. It looks ok but it is not right for the "914 follower". My reasoning was to match the oil capacity of the engine requirements plus front oil cooler. I built to handle the "warm" Arizona summers and it has done the job very well. I built a18 quart capacity which gives me plently of cooling during the summers, winters do not drive since I live in the "high country" and it is cold out there.
I could have used the Peterson type located in the front but I believe the oil has to as close to the engine as possible and level with the engine inlet. Sorry I did it? No! It satisfies my needs and does the job well. Not according well accepted and called a "bastard". I agree with this statement and would not do it on a normal 914. My car has been retrieved from the "junkyard" and I built it with available parts. I did have a sixes original oil tank but it just did not fit my needs. Way back, there were a series of local articles on converting the 911 tank to the 914 location. I do not remember exactly but the bottom of the tank had to be narrowed and something had to be done to the internals of the tank. Increased capacity in the original tank was also done by cutting the tank apart and putting a metal section; again, probably something had to be done to the internals of the tank. In sum, find a solution to your needs and build; be happy and enjoy. As an alternative for cleanliness, probably the Peterson tank is the best. Most people put it up front taking up valuable "real estate" in the front trunk. Food for thought. Steve |
914itis oil tank Aug 12 2013, 11:01 AM
SLITS NO Aug 12 2013, 11:12 AM
ConeDodger 911 tank? Aug 12 2013, 11:14 AM
r_towle yes 911 tank.
I wonder, would it fit on the other... Aug 12 2013, 11:56 AM
914itis Yeah 911SC Aug 12 2013, 12:42 PM
brant only in a 911 Aug 12 2013, 12:56 PM
r_towle
only in a 911
has anyone tried to make it fit on... Aug 12 2013, 01:27 PM
mepstein Don't hack up the car. Do it with the right ki... Aug 12 2013, 01:18 PM
914itis No, I will order one from them.
Thanks. Aug 12 2013, 01:25 PM
914itis I am not going to start until mid-winter anyway. B... Aug 12 2013, 02:27 PM
worn
I ... Aug 12 2013, 03:19 PM
SLITS The only one I have seen with a 911 tank everybody... Aug 12 2013, 03:58 PM
pcar916 If I were to run a tank in the front the return li... Aug 13 2013, 09:11 AM![]() ![]() |
Lo-Fi Version | Time is now: 18th April 2026 - 03:50 AM |
