| naro914 |
Aug 12 2013, 07:01 PM
Losing my mind... ![]() ![]() ![]() ![]() Group: Members Posts: 2,476 Joined: 26-May 06 From: Charlotte, NC Member No.: 6,073 Region Association: South East States |
Need some ideas for a friend with a 2.4 liter 6 in his 914. He doesn't want to hack into the car and mount a cooler up front and run lines back and forth - wants to keep the body stock with no holes cut all over, wants to keep heat, and its a street driver for fun stuff with all interior in it, not any sort of track car or anything like that.
He's having all sorts of heating problems - oil getting way too hot... What has anyone done to mount a cooler in the back that's worked? Where, how, and what cooler? Thanks |
| Elliot Cannon |
Aug 13 2013, 01:48 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Retired Members Posts: 8,487 Joined: 29-December 06 From: Paso Robles Ca. (Central coast) Member No.: 7,407 Region Association: None
I don't think it matters where the cooler is located. Most important is the volume of air flowing through the cooler and a route for the air to flow smoothly and swiftly out of the cooler after it passes through.
naro914 Engine/oil cooling for a six, Aug 12 2013, 07:01 PM
JmuRiz Rich Johnson has a contact that makes the one he u... Aug 12 2013, 07:03 PM
chad newton Tell the dude to get over it, it's just a 914.... Aug 12 2013, 09:47 PM
chad newton I don't see why you couldn't fab up a moun... Aug 12 2013, 10:23 PM
chad newton Also that one guy on either mine or your other thr... Aug 12 2013, 10:25 PM
Elliot Cannon NACA scoop in the rocker panel ducted to a small s... Aug 12 2013, 11:19 PM
McMark For a street driver, I wouldn't expect a 2.4 t... Aug 13 2013, 12:14 AM
naro914
For a street driver, I wouldn't expect a 2.4 ... Aug 13 2013, 05:54 AM
Racer Chris On a 3.6 we installed, we placed two of the Setrab... Aug 13 2013, 04:10 AM
JmuRiz Does it have the under-body cooling flaps?
FYI, t... Aug 13 2013, 08:16 AM
jeff The perfect solution.. Aug 13 2013, 08:22 AM
tradisrad Here is a topic I started several years ago: Exter... Aug 13 2013, 08:37 AM
pcar916 Here's a thread (Paddock) about a transaxle co... Aug 13 2013, 09:27 AM
carr914
For a street driver, I wouldn't expect a 2.4... Aug 14 2013, 04:53 AM
naro914
Need to address why it is getting so Hot before p... Aug 14 2013, 05:48 AM
Justin Fischer Are the temp gauge and sender correct? Aug 14 2013, 06:48 AM
shuie I would expect anything more than a completely sto... Aug 14 2013, 07:10 AM
r_towle I visited a hotrod shop and saw something like thi... Aug 14 2013, 07:38 AM
pcar916 My first six engine was a Bruce Anderson "E... Aug 14 2013, 08:05 AM
chad newton Ring gap??? I'm no engine builder but I know ... Aug 14 2013, 08:23 AM
jeff If it his engine has been running hot from the sta... Aug 14 2013, 09:00 AM![]() ![]() |
Lo-Fi Version | Time is now: 14th March 2026 - 02:33 AM |
