lsintampa |
Senior Member ![]() ![]() ![]() Group: Members Posts: 520 Joined: 28-January 13 From: Tampa, FL Member No.: 15,441 Region Association: South East States ![]() |
75 914/4 2.0 FI
OK, so while I'm waiting on the final verdict on my fuel injector cleaning project, I thought I'd chase down an oil leak. What I found was that oil was seeping out of the cover plate for the remote oil temp sender. I removed the cover plate that is held on by two 10mm bolts. With the cover removed, oil really seeped out of the bolt holes. I assume and hope that's OK? Question is, if they leak that bad, shouldn't there be a gasket for that cover? The cover and the plate that the sender mounts to were very nicely cleaned and powder coated, but no gasket. I see a gasket in the PET, but not sure if it is for the cover plate or the inside plate that the temp sender screws into? Thanks, Len |
r_towle |
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,705 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States ![]() ![]() |
gasket
plate with sender gasket o-ring cover plate Both bolts have copper crush washers (one use only) as well. All of this is in a standard gasket kit, or you can get them all from one of the many vendors that we all buy from. rich |
Lo-Fi Version | Time is now: 1st August 2025 - 06:20 AM |
