> Engine/oil cooling for a six,, need ideas for a friend of mine
naro914
post Aug 12 2013, 07:01 PM
Losing my mind...
Need some ideas for a friend with a 2.4 liter 6 in his 914. He doesn't want to hack into the car and mount a cooler up front and run lines back and forth - wants to keep the body stock with no holes cut all over, wants to keep heat, and its a street driver for fun stuff with all interior in it, not any sort of track car or anything like that.
He's having all sorts of heating problems - oil getting way too hot...
What has anyone done to mount a cooler in the back that's worked? Where, how, and what cooler?
Thanks
carr914
post Aug 14 2013, 04:53 AM
Racer from Birth
QUOTE(naro914 @ Aug 13 2013, 07:54 AM) *
QUOTE(McMark @ Aug 13 2013, 01:14 AM) *
For a street driver, I wouldn't expect a 2.4 to overheat, unless something is wrong. I know of a street driven 3.2 without additional cooling. I agree, check the engine and tuning first.
It just got a complete rebuild literally last week. It ran hot since the beginning when it was installed years ago from a different mechanic/builder. New build replaced a lot of things that the original guy did wrong, but still same issue. Saw temps of 230-240 driving it home from the install, and he does have a cooler on it mounted underneath (I don't have pics). Can't figure out what's going on...
Need to address why it is getting so Hot before putting a Band-Aid on it
naro914
post Aug 14 2013, 05:48 AM
Losing my mind...
QUOTE(carr914 @ Aug 14 2013, 05:53 AM) *
thoughts?
Stock (factory) 914/6 oil tank to engine. Everything in engine was checked and cleaned, new P&C's, heads rebuilt, new valve guides/valves. Engine oil cooler cleaned out. Not much else there to check.
naro914   Engine/oil cooling for a six,   Aug 12 2013, 07:01 PM
JmuRiz   Rich Johnson has a contact that makes the one he u...   Aug 12 2013, 07:03 PM
chad newton   Tell the dude to get over it, it's just a 914....   Aug 12 2013, 09:47 PM
chad newton   I don't see why you couldn't fab up a moun...   Aug 12 2013, 10:23 PM
chad newton   Also that one guy on either mine or your other thr...   Aug 12 2013, 10:25 PM
Elliot Cannon   NACA scoop in the rocker panel ducted to a small s...   Aug 12 2013, 11:19 PM
McMark   For a street driver, I wouldn't expect a 2.4 t...   Aug 13 2013, 12:14 AM
naro914   For a street driver, I wouldn't expect a 2.4 ...   Aug 13 2013, 05:54 AM
Racer Chris   On a 3.6 we installed, we placed two of the Setrab...   Aug 13 2013, 04:10 AM
JmuRiz   Does it have the under-body cooling flaps? FYI, t...   Aug 13 2013, 08:16 AM
jeff   The perfect solution..   Aug 13 2013, 08:22 AM
tradisrad   Here is a topic I started several years ago: Exter...   Aug 13 2013, 08:37 AM
pcar916   Here's a thread (Paddock) about a transaxle co...   Aug 13 2013, 09:27 AM
Elliot Cannon   I don't think it matters where the cooler is l...   Aug 13 2013, 01:48 PM
carr914   For a street driver, I wouldn't expect a 2.4...   Aug 14 2013, 04:53 AM
naro914   Need to address why it is getting so Hot before p...   Aug 14 2013, 05:48 AM
Justin Fischer   Are the temp gauge and sender correct?   Aug 14 2013, 06:48 AM
shuie   I would expect anything more than a completely sto...   Aug 14 2013, 07:10 AM
r_towle   I visited a hotrod shop and saw something like thi...   Aug 14 2013, 07:38 AM
pcar916   My first six engine was a Bruce Anderson "E...   Aug 14 2013, 08:05 AM
chad newton   Ring gap??? I'm no engine builder but I know ...   Aug 14 2013, 08:23 AM
jeff   If it his engine has been running hot from the sta...   Aug 14 2013, 09:00 AM
- Lo-Fi Version Time is now: 14th March 2026 - 02:38 AM
