> Engine/oil cooling for a six,, need ideas for a friend of mine
naro914
post Aug 12 2013, 07:01 PM
Losing my mind...
Need some ideas for a friend with a 2.4 liter 6 in his 914. He doesn't want to hack into the car and mount a cooler up front and run lines back and forth - wants to keep the body stock with no holes cut all over, wants to keep heat, and its a street driver for fun stuff with all interior in it, not any sort of track car or anything like that.
He's having all sorts of heating problems - oil getting way too hot...
What has anyone done to mount a cooler in the back that's worked? Where, how, and what cooler?
Thanks
shuie
post Aug 14 2013, 07:10 AM
I would expect anything more than a completely stock low compression 2.4T with all of the engine bay seals and everything else in place and in perfect working order to need an external cooler. Hotter plugs, missing seals, Summer, traffic, etc., can make even a stock T motor run up into the 250 range pretty quickly.
naro914   Engine/oil cooling for a six,   Aug 12 2013, 07:01 PM
JmuRiz   Rich Johnson has a contact that makes the one he u...   Aug 12 2013, 07:03 PM
chad newton   Tell the dude to get over it, it's just a 914....   Aug 12 2013, 09:47 PM
chad newton   I don't see why you couldn't fab up a moun...   Aug 12 2013, 10:23 PM
chad newton   Also that one guy on either mine or your other thr...   Aug 12 2013, 10:25 PM
Elliot Cannon   NACA scoop in the rocker panel ducted to a small s...   Aug 12 2013, 11:19 PM
McMark   For a street driver, I wouldn't expect a 2.4 t...   Aug 13 2013, 12:14 AM
naro914   For a street driver, I wouldn't expect a 2.4 ...   Aug 13 2013, 05:54 AM
Racer Chris   On a 3.6 we installed, we placed two of the Setrab...   Aug 13 2013, 04:10 AM
JmuRiz   Does it have the under-body cooling flaps? FYI, t...   Aug 13 2013, 08:16 AM
jeff   The perfect solution..   Aug 13 2013, 08:22 AM
tradisrad   Here is a topic I started several years ago: Exter...   Aug 13 2013, 08:37 AM
pcar916   Here's a thread (Paddock) about a transaxle co...   Aug 13 2013, 09:27 AM
Elliot Cannon   I don't think it matters where the cooler is l...   Aug 13 2013, 01:48 PM
carr914   For a street driver, I wouldn't expect a 2.4...   Aug 14 2013, 04:53 AM
naro914   Need to address why it is getting so Hot before p...   Aug 14 2013, 05:48 AM
Justin Fischer   Are the temp gauge and sender correct?   Aug 14 2013, 06:48 AM
shuie   I would expect anything more than a completely sto...   Aug 14 2013, 07:10 AM
r_towle   I visited a hotrod shop and saw something like thi...   Aug 14 2013, 07:38 AM
pcar916   My first six engine was a Bruce Anderson "E...   Aug 14 2013, 08:05 AM
chad newton   Ring gap??? I'm no engine builder but I know ...   Aug 14 2013, 08:23 AM
jeff   If it his engine has been running hot from the sta...   Aug 14 2013, 09:00 AM
- Lo-Fi Version Time is now: 14th March 2026 - 02:38 AM
