Hammer920 |
It's a Learning Experience ![]() ![]() Group: Members Posts: 83 Joined: 27-April 04 From: Levelland, TX Member No.: 1,989 ![]() |
(IMG:style_emoticons/default/confused24.gif) I have dropped the engine and tranny and now have gone down as far as the piston cylienders abd heads, there were no gaskets on then at all the push rod tubes had orange silicone on the seals some were just o-rings not for the porshe itself some were some other kind of seals. I ordered a complete set from pelican parts, the 1st Question is this, when i took off the drivers side head one of the fins on cylender 4 partially broke off about 4 " of it, will that effect the cooling of it. 2nd question the pistons in cylender 2&4 and the valves are clean, the 1&3 piston heads have carbon bild up on top of the piston and valves cylender walls are smooth as a baby's butt, should I take the piston cylenders off and have them polished and cleaned or scrape off the carbon build up and put back togeather I dont have the ring compressor to put them back on. there were a lot of things that i saw that was not right or missing. any suggestions would be appreciated. (IMG:style_emoticons/default/wacko.gif)
watsonrx13 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,735 Joined: 18-February 03 From: Plant City, FL Member No.: 312 Region Association: South East States ![]() |
Wow, now that looks filthy.
Hey Joe, I guess my engine isn't that bad after all... (IMG:style_emoticons/default/smilie_pokal.gif) Listen to everyone, get a Haynes manual and do it right. Also, Joe is rebuilding my engine. Here's what he found. Attached image(s) ![]() |
Lo-Fi Version | Time is now: 1st August 2025 - 01:00 AM |
