| NFBrown |
Aug 15 2013, 10:44 AM
Newbie ![]() Group: Members Posts: 34 Joined: 27-February 13 From: Boise, Idaho Member No.: 15,587 Region Association: Pacific Northwest |
I just got a dandy new stock shift knob but I can't get the beat-up leather covered one off. Of couse I don't know how it's attached (just bought the car) but assuming it used a stock crush washer should it just pull off? I probably should get a new crush washer before I cut the knob off (IMG:style_emoticons/default/dry.gif)
Always wanted a 914, finally got one. Please help the newbe. Nick |
| Eric_Shea |
Aug 15 2013, 11:23 AM
PMB Performance ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 19,304 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
QUOTE My guess is that it was glued on because the PO didn't know about the crush washer. (IMG:style_emoticons/default/agree.gif) You would have to heat the shaft to 500 degrees with a torch and then use a proper open end wrench (16mm) and tap it up and off. |
NFBrown Shift knob removal Aug 15 2013, 10:44 AM
76-914 My guess is that it was glued on because the PO di... Aug 15 2013, 11:12 AM
stugray To start with, I would put a crescent or open end ... Aug 15 2013, 11:22 AM
Rob-O Post a pic of the leather covered one. Many had s... Aug 15 2013, 11:57 AM
luskesq Before you go hammering on stuff, make sure there ... Aug 15 2013, 11:59 AM
rick 918-S I have one that has a threaded collar at the base ... Aug 15 2013, 03:11 PM
Vacca Rabite Agree with everyone else.
Check for the set screw... Aug 15 2013, 03:33 PM
r_towle just use a sawzall and shorten the shaft...its too... Aug 15 2013, 04:38 PM
NFBrown It "was" glued on. It's in pieces n... Aug 15 2013, 06:01 PM
Vacca Rabite You can use paper or felt (better) instead of a cr... Aug 15 2013, 06:08 PM![]() ![]() |
Lo-Fi Version | Time is now: 16th April 2026 - 06:44 PM |
