mig help - quick release fitting size help |
jimkelly |
Aug 12 2013, 12:50 PM
Delaware USA Group: Members Posts: 4,969 Joined: 5-August 04 From: Delaware, USA Member No.: 2,460 Region Association: MidAtlantic Region |
I need to order a female quick release fitting from McMaster carr.
the tube is 6mm od - or - are these tubes based on ID, in which case it may be 4mm?? I need a fitting for the tank valve and the male threaded connector is 13mm OD and has a 9/16 nut on it. I went to roberts oxygen for the argon tank but they did not have the fitting,. nor did my local fastenall, nor did ace, nor did tractor supply : ( which pn should I be ordering? I think I need 1/4 ID for the tube quick release and 1/2 in npt female thread?? but it looks like 3/8 is a much for likely thread size? http://www.mcmaster.com/#push-to-connect-t...ittings/=o19u3o oh yeah - got a tank of 75/25 : ) for $50 I can get a brand new regulator and hose on ebay and since my regulator appears to have been dropped at on point, i am thinking this may be the way to go? http://www.ebay.com/itm/Argon-CO2-Flowmete...=item5659c7f5f3 I will hit harbor freight and see what they have first. Attached thumbnail(s) |
jimkelly |
Aug 16 2013, 03:28 PM
damn it.
got the hose but it has 3/8 fitting at both ends and 3/8 does not fit in my mig. also, I need to come out of my machine with an elbow or my line and tank interfere. so I just ordered this fitting, 6mm hose and 1.4 thread. this should connect directly to my regulator. it sucks here in southern delaware and there are no real suppliers of anything nearby. Attached image(s) |
Lo-Fi Version | Time is now: 8th June 2024 - 04:18 PM |
