| tornik550 |
Aug 16 2013, 03:23 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,248 Joined: 29-January 07 From: Ohio Member No.: 7,486 Region Association: None |
I have a 2258 -4. My engine is a fairly fresh rebuild. I have been keeping a very close eye on my oil pressure because I had a burst oil pressure line and had to drive the car at 0 pressure for about one minute. My oil pressure is the same as before the incident. When the oil temp is around the max for my engine (210), I have an oil pressure that is essentially equal to the rpm's (divided by 100- so rpm 1000 would be oil pressure of 10).
I have a schadek 26mm oil pump. I use fresh brad penn 20/50 oil. Do my oil temps sound reasonable? If they are low, how can I increase oil pressure? |
| SLITS |
Aug 16 2013, 05:26 PM
"This Utah shit is HARSH!" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None |
Everybody throws around 10 psig per 1000 rpm. By that you are golden.
210 oil temp is where it works the best. Oil pressure is a function of the clearances that were built into the engine as far as I am concerned. When I built racing engines, they were built with clearances like a 300,000 mile engine ... 8500 rpm gave 55 psig at 220 - 230 oil temps. Other experts can chime in with their numbers. |
tornik550 What is normal oil pressure? Aug 16 2013, 03:23 PM
worn
Everybody throws around 10 psig per 1000 rpm. By... Aug 16 2013, 08:21 PM
SLITS
Everybody throws around 10 psig per 1000 rpm. B... Aug 16 2013, 09:16 PM
eyesright Page 20 of Haynes says SAE 30 @ 70C/158F @2500RPM ... Aug 17 2013, 04:38 PM![]() ![]() |
Lo-Fi Version | Time is now: 22nd June 2026 - 12:52 AM |
