Demick |
Ernie made me do it! ![]() ![]() ![]() ![]() Group: Benefactors Posts: 2,312 Joined: 6-February 03 From: Pleasanton, CA Member No.: 257 ![]() ![]() |
I've found a bunch of surprises while tearing down my engine, but none as big as what I found last night. I'm not even sure what prompted me to measure the cylinder diameter, but when I did I got quite a surprise. 96mm P&C's which means I've had a 2.056 motor all this time and never knew it! I feel bad that I've been running in stock engine classes for autocross for all these years - but then again, most of the people running probably don't know for sure the internals of their motors either. Mine was rebuilt over 20 years ago (that's 5 owners ago!).
So this really screws up my rebuilding plans. I had planned to do a stock rebuild using the higher compression euro pistons. I had thought that this rebuild would give me about 10hp over what I had before (5hp for the euro pistons, and another 5hp due to a fresh engine). But now I'm thinking maybe I should build the engine a little more agressively. Continue with 96mm pistons, but go higher on the compression like somewhere around 8.5:1 (my engine had dished pistons and probably a fairly stock compression ratio since I always ran regular gas with no problems). Maybe a little head work to get the engine to breathe a little better...... Hmmm..... Basically build the engine to the limit of what I can run with the stock d-jet F.I. Decisions, Decisions. Luckily I haven't bought any hard parts yet..... Demick Attached image(s) ![]() |
Demick |
Michael
Just click the "Website" link at the bottom of any of my posts. That will take you to my website which has links to all of the different write-ups that I have done. Demick |
Lo-Fi Version | Time is now: 17th June 2024 - 07:09 AM |
