> Daul single throat 34s ?, vacuum advance, runninig rich
Hine62
post Aug 18 2013, 10:46 AM
I've just installed dual 34 carbs (EMPI) with the equalizer tube between both manifolds and can't get a good fuel mixture. (The distributor is vacuum and centrifugal.) Tried both sets of jets. Would timing be causing this problem?? Or maybe I need to connect the vacuum from both carbs to dist?
Any help would be great!
pilothyer
post Aug 18 2013, 01:55 PM
Do you have a way to check the fuel pressure ? Could be that the dual webber ICT carbs a a bit more sensitive to excessive fuel pressure. If it is over 2 psi that may be your problem. Which fuel pump are you using ? If the pressure is ok you most likely need to readjust the float levels.....If gasoline is building up inside the carbs (one or both) it is because the floats are not closing the inlet valve and shutting the fuel off when the bowl is full. You will need to bend the tang a bit so that when the float rises the tang will push the valve closed, while you check that see if the seats and the valves are in good condition. You will need to determine it you have brass or plastic floats before you can get the exact measurement for float adjustment.
Hine62   Daul single throat 34s ?   Aug 18 2013, 10:46 AM
vw505   Did you set the floats.   Aug 18 2013, 10:52 AM
Hine62   I didn't know I had to. How are they set?   Aug 18 2013, 11:02 AM
rmital   I didn't know I had to. How are they set? Wo...   Aug 18 2013, 06:39 PM
pilothyer   I didn't know I had to. How are they set? W...   Aug 18 2013, 07:17 PM
rmital   ...could you describe the reason or the sympton of...   Aug 18 2013, 11:12 AM
Hine62   White smoke coming out the tail pipe on both sides...   Aug 18 2013, 11:23 AM
rmital   White smoke coming out the tail pipe on both side...   Aug 18 2013, 11:28 AM
kg6dxn   Have you read this? http://www.redlineweber.com/h...   Aug 18 2013, 11:23 AM
Hine62   Just took off the single carb that ran fine for du...   Aug 18 2013, 12:15 PM
pilothyer   Do you have a way to check the fuel pressure ? Co...   Aug 18 2013, 01:55 PM
chad newton   Did you try running more intial timing? Some guys...   Aug 18 2013, 02:00 PM
pilothyer   Here Is a diagram along with part numbers for your...   Aug 18 2013, 02:26 PM
Racer Chris   What camshaft is in the engine? Those carbs won...   Aug 18 2013, 04:47 PM
Hine62   Thanks for the replies! The fuel pressure was ...   Aug 18 2013, 06:26 PM
nathansnathan   Everything I've read about weber 34ict's s...   Aug 19 2013, 06:30 AM
Eric_Shea   What size engine? What cam? Altitude is 900ft. Wha...   Aug 19 2013, 09:08 AM
Hine62   The engine is a 1.8l with stock cam and svda dist....   Aug 19 2013, 10:09 AM
Joe Sharp   In the diagram form post number 6 above the item n...   Aug 19 2013, 11:20 AM
pilothyer   Weber 34 ICT with plastic floats Should be set at ...   Aug 19 2013, 12:32 PM
Eric_Shea   Your jets are spot on for your altitude. What are...   Aug 19 2013, 02:14 PM
Hine62   thanks again. We got it sorted out! After adju...   Aug 19 2013, 02:48 PM
- Lo-Fi Version Time is now: 1st May 2026 - 06:33 AM
