> Daul single throat 34s ?, vacuum advance, runninig rich
Hine62
post Aug 18 2013, 10:46 AM
I've just installed dual 34 carbs (EMPI) with the equalizer tube between both manifolds and can't get a good fuel mixture. (The distributor is vacuum and centrifugal.) Tried both sets of jets. Would timing be causing this problem?? Or maybe I need to connect the vacuum from both carbs to dist?
Any help would be great!
chad newton
post Aug 18 2013, 02:00 PM
Did you try running more intial timing? Some guys go exactly by the book and sometimes that dosnt work, especially with carborators.
Hine62   Daul single throat 34s ?   Aug 18 2013, 10:46 AM
vw505   Did you set the floats.   Aug 18 2013, 10:52 AM
Hine62   I didn't know I had to. How are they set?   Aug 18 2013, 11:02 AM
rmital   I didn't know I had to. How are they set? Wo...   Aug 18 2013, 06:39 PM
pilothyer   I didn't know I had to. How are they set? W...   Aug 18 2013, 07:17 PM
rmital   ...could you describe the reason or the sympton of...   Aug 18 2013, 11:12 AM
Hine62   White smoke coming out the tail pipe on both sides...   Aug 18 2013, 11:23 AM
rmital   White smoke coming out the tail pipe on both side...   Aug 18 2013, 11:28 AM
kg6dxn   Have you read this? http://www.redlineweber.com/h...   Aug 18 2013, 11:23 AM
Hine62   Just took off the single carb that ran fine for du...   Aug 18 2013, 12:15 PM
pilothyer   Do you have a way to check the fuel pressure ? Co...   Aug 18 2013, 01:55 PM
chad newton   Did you try running more intial timing? Some guys...   Aug 18 2013, 02:00 PM
pilothyer   Here Is a diagram along with part numbers for your...   Aug 18 2013, 02:26 PM
Racer Chris   What camshaft is in the engine? Those carbs won...   Aug 18 2013, 04:47 PM
Hine62   Thanks for the replies! The fuel pressure was ...   Aug 18 2013, 06:26 PM
nathansnathan   Everything I've read about weber 34ict's s...   Aug 19 2013, 06:30 AM
Eric_Shea   What size engine? What cam? Altitude is 900ft. Wha...   Aug 19 2013, 09:08 AM
Hine62   The engine is a 1.8l with stock cam and svda dist....   Aug 19 2013, 10:09 AM
Joe Sharp   In the diagram form post number 6 above the item n...   Aug 19 2013, 11:20 AM
pilothyer   Weber 34 ICT with plastic floats Should be set at ...   Aug 19 2013, 12:32 PM
Eric_Shea   Your jets are spot on for your altitude. What are...   Aug 19 2013, 02:14 PM
Hine62   thanks again. We got it sorted out! After adju...   Aug 19 2013, 02:48 PM
- Lo-Fi Version Time is now: 1st May 2026 - 06:33 AM
