> Rear brakes and e-brake...
edhall
post Aug 15 2013, 12:02 AM
Hi guys, just joined as I've just got a 914. Need a little help with parts compatibility and wondered if anyone could help?
Car is a 74 914 with a 3.2 Carrera engine, 901 trans, and it stops with 911 SC vented rotors and calipers all round. Thing is, it doesn't have an emergency brake. The car was built in California but here in the uk it cannot be road legal without one.
Do I go 911 style drum in disc or 914 style ebrake on a calipers?
Thanks in advance
TurboWalt
post Aug 19 2013, 06:15 AM
I currently have the Renegade "Big Red" caliper setup on my car. I don't know what the specs of the rear caliper are. I presently don't have a handbrake. I will want one when my car hits the street. Is my best bet at this point to go the 911 route (Tangerine)? Should I use the 914/6 GT calipers on the rear, would I lose the proper balance mentioned by Eric? Does anyone have any experience with the kit I'm using, is it properly balanced?
Thanks, Walt
(IMG:http://www.914world.com/bbs2/uploads_offsite/www.renegadehybrids.com-11463-1376914540.1.jpg)
Eric_Shea
post Aug 19 2013, 07:38 AM
PMB Performance
QUOTE(TurboWalt @ Aug 19 2013, 06:15 AM) *
Thanks, Walt
You be loosing a lot of rear brake. Go with the CFR kit and I have a set of 911 handbrake assemblies.
edhall   Rear brakes and e-brake...   Aug 15 2013, 12:02 AM
type47   I'd say get some 914 rear brakes from Eric She...   Aug 15 2013, 05:44 AM
Racer Chris   ... not have to engineer the pull mechanism ... T...   Aug 15 2013, 08:36 AM
andys   ... not have to engineer the pull mechanism ... ...   Aug 15 2013, 12:25 PM
Racer Chris   Chris, On your cable adapter, do you remove one ...   Aug 15 2013, 12:41 PM
jimkelly   eric's site http://www.pmbperformance.com/914...   Aug 15 2013, 06:23 AM
mepstein   PMB sells a 914-6 rear brake replica in aluminum t...   Aug 15 2013, 06:25 AM
chad newton   PMB sells a 914-6 rear brake replica in aluminum ...   Aug 18 2013, 10:17 PM
aharder   :wttc:   Aug 15 2013, 07:00 AM
green914   :wttc:   Aug 15 2013, 09:14 AM
Eric_Shea   For all of the money and time you would spend fitt...   Aug 15 2013, 11:15 AM
Racer Chris   This is, in fact, why we went forward developing ...   Aug 15 2013, 11:40 AM
worn   For all of the money and time you would spend fit...   Aug 15 2013, 01:33 PM
Eric_Shea   For all of the money and time you would spend fi...   Aug 15 2013, 07:58 PM
worn   SC parts will be even more difficult to fit. The...   Aug 16 2013, 11:39 AM
914_teener   SC parts will be even more difficult to fit. Th...   Aug 16 2013, 12:05 PM
worn   :shades2: Well, yeah you are right. But he...   Aug 16 2013, 12:34 PM
Trekkor   http://www.rockauto.com/ has several options. 91...   Aug 15 2013, 01:23 PM
Eric_Shea   You'll have to read up on that. there's a...   Aug 15 2013, 01:26 PM
Trekkor   http://www.oreillyauto.com/site/c/search/B...tkeyw...   Aug 15 2013, 01:33 PM
Cap'n Krusty   [url=http://www.oreillyauto.com/site/c/search/Bra...   Aug 15 2013, 02:57 PM
Trekkor   To all those using brake parts sourced from Roc...   Aug 15 2013, 07:31 PM
DBCooper   To all those using brake parts sourced from Ro...   Aug 16 2013, 09:49 AM
worn   [url=http://www.oreillyauto.com/site/c/search/Br...   Aug 16 2013, 11:34 AM
Cap'n Krusty   Hi guys, just joined as I've just got a 914. ...   Aug 15 2013, 02:59 PM
r_towle   Mid 90's vw passat looks like it may work on v...   Aug 15 2013, 08:01 PM
jcd914   Mid 90's vw passat looks like it may work on ...   Aug 15 2013, 09:57 PM
Elliot Cannon   I have PMB's alloy 914/6 calipers on my car. ...   Aug 15 2013, 10:58 PM
Socalandy   PMB 914-6GT calipers on my ride with Stock E-brake...   Aug 15 2013, 11:26 PM
edhall   This is all great stuff. Thanks! I'll spen...   Aug 16 2013, 06:11 AM
monkeyboy   When I first picked up my 914 years ago, the manag...   Aug 16 2013, 11:28 AM
Trekkor   http://www.cardone.com/products/brakes I trust th...   Aug 16 2013, 01:52 PM
Trekkor   Front: https://sphotos-a.xx.fbcdn.net/hphotos-prn...   Aug 16 2013, 02:20 PM
Eric_Shea   Lets see if we can get this quote thing right......   Aug 16 2013, 02:58 PM
worn   The SC front would work. If it's for street ...   Aug 16 2013, 08:58 PM
Eric_Shea   I like S-Calipers. But they're expensive. Othe...   Aug 16 2013, 10:20 PM
Racer Chris   ... stay with a 3" strut an go Brembo. At 4l...   Aug 17 2013, 07:38 AM
Steve   Eric's solution is the way to go. IMHO, to go...   Aug 18 2013, 09:57 AM
Racer Chris   Eric's solution is the way to go. IMHO, to g...   Aug 18 2013, 10:18 AM
Jeff Hail   Eric's solution is the way to go. IMHO, to g...   Aug 18 2013, 12:57 PM
Steve   I agree and if someone wanted to go down the 911 e...   Aug 18 2013, 11:09 AM
Steve   :agree: Wes did all that work on my trailing arms...   Aug 18 2013, 01:11 PM
Eric_Shea   Here's my take; many think I'm a big brake...   Aug 18 2013, 01:33 PM
Jeff Hail   Here's my take; many think I'm a big brak...   Aug 18 2013, 01:55 PM
Racer Chris   ... I simply don't think enormous brakes are ...   Aug 18 2013, 04:40 PM
Eric_Shea   I decided to go with the stock solution and sold t...   Aug 18 2013, 02:02 PM
Jeff Hail   I decided to go with the stock solution and sold ...   Aug 18 2013, 03:07 PM
worn   I decided to go with the stock solution and sold ...   Aug 19 2013, 05:12 PM
jaxdream   I decided to go with the stock solution and sold...   Aug 19 2013, 07:16 PM
Racer Chris   You will have to fashion a 40mm or so bracket wel...   Aug 19 2013, 09:40 PM
Steve   I am also running stock Boxster brakes up front. ...   Aug 18 2013, 03:07 PM
Eric_Shea   Read post #8 in this thread. (or post #22... or po...   Aug 18 2013, 10:19 PM
chad newton   Read post #8 in this thread. (or post #22... or p...   Aug 18 2013, 10:52 PM
TurboWalt   I currently have the Renegade "Big Red" ...   Aug 19 2013, 06:15 AM
Eric_Shea   I currently have the Renegade "Big Red...   Aug 19 2013, 07:38 AM
Racer Chris   I have some SC brake tophats available. They fit o...   Aug 19 2013, 09:12 AM
Jeff Hail   Shave the shiny areas until the hat/ backing plate...   Aug 19 2013, 06:09 PM
Jeff Hail   First pic to give an idea what the 11 arm looks li...   Aug 19 2013, 07:57 PM
jaxdream   First pic to give an idea what the 11 arm looks l...   Aug 20 2013, 07:46 AM
brant   Now I'm curious eric. What is the front to r...   Aug 19 2013, 09:56 PM
DBCooper   I haven't been to your site in a while, Chris,...   Aug 19 2013, 09:57 PM
Racer Chris   I haven't been to your site in a while, Chris...   Aug 20 2013, 11:50 AM
- Lo-Fi Version Time is now: 11th October 2026 - 06:59 PM
