> Problems with redline conversion kits ?
dbreitkreutz
post Aug 17 2013, 12:32 PM
I am trying to install a redline conversion kit #K 297. Which is the progressive two barrel weber on my 2.0 l. I cannot get the manifolds to align up properly to the cast carb base. I have tried with the swap of manifolds, but if I can get it to mate with the manifold it is way off the bubble on the level.
Has anybody used this kit that worked or not.
Daniel
dbreitkreutz
post Aug 19 2013, 08:34 AM
OK, I get it. I was just trying to get the "little Guy" more streetable. I have Weber's 44 IDF pair on it now. I have been trying to "tune" them now for several years and just thought this conversion might be the trick. I am wrong.
The webers need rebuilding and chocked down on the venturies and main jets. It has been loading up on fuel and killing the plugs. So I will continue to work with the 44's and return the conversion kit.
I apologize for my comments and if anybody has a chart with the ratio of a main jet to the correction, if the main is sized smaller does the correction need to follow and how much.
Thanks again for any help.
- Lo-Fi Version Time is now: 11th September 2026 - 09:43 PM
