| Hine62 |
Aug 18 2013, 10:46 AM
Member ![]() ![]() Group: Members Posts: 132 Joined: 4-October 12 From: Binghamton, NY Member No.: 15,000 Region Association: None |
I've just installed dual 34 carbs (EMPI) with the equalizer tube between both manifolds and can't get a good fuel mixture. (The distributor is vacuum and centrifugal.) Tried both sets of jets. Would timing be causing this problem?? Or maybe I need to connect the vacuum from both carbs to dist?
Any help would be great! |
| Eric_Shea |
Aug 19 2013, 02:14 PM
PMB Performance ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 19,304 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
Your jets are spot on for your altitude.
What are the idle jets? |
Hine62 Daul single throat 34s ? Aug 18 2013, 10:46 AM
vw505 Did you set the floats. Aug 18 2013, 10:52 AM
Hine62 I didn't know I had to. How are they set? Aug 18 2013, 11:02 AM
rmital
Wo... Aug 18 2013, 06:39 PM
pilothyer
W... Aug 18 2013, 07:17 PM
rmital ...could you describe the reason or the sympton of... Aug 18 2013, 11:12 AM
Hine62 White smoke coming out the tail pipe on both sides... Aug 18 2013, 11:23 AM
rmital
White smoke coming out the tail pipe on both side... Aug 18 2013, 11:28 AM
kg6dxn Have you read this?
http://www.redlineweber.com/h... Aug 18 2013, 11:23 AM
Hine62 Just took off the single carb that ran fine for du... Aug 18 2013, 12:15 PM
pilothyer Do you have a way to check the fuel pressure ? Co... Aug 18 2013, 01:55 PM
chad newton Did you try running more intial timing? Some guys... Aug 18 2013, 02:00 PM
pilothyer Here Is a diagram along with part numbers for your... Aug 18 2013, 02:26 PM
Racer Chris What camshaft is in the engine?
Those carbs won... Aug 18 2013, 04:47 PM
Hine62 Thanks for the replies! The fuel pressure was ... Aug 18 2013, 06:26 PM
nathansnathan Everything I've read about weber 34ict's s... Aug 19 2013, 06:30 AM
Eric_Shea What size engine?
What cam?
Altitude is 900ft.
Wha... Aug 19 2013, 09:08 AM
Hine62 The engine is a 1.8l with stock cam and svda dist.... Aug 19 2013, 10:09 AM
Joe Sharp In the diagram form post number 6 above the item n... Aug 19 2013, 11:20 AM
pilothyer Weber 34 ICT with plastic floats Should be set at ... Aug 19 2013, 12:32 PM
Hine62 thanks again. We got it sorted out! After adju... Aug 19 2013, 02:48 PM![]() ![]() |
Lo-Fi Version | Time is now: 1st May 2026 - 06:35 AM |
