> Crank end play
jmargush
post Aug 19 2013, 06:08 PM
I am at the point of checking end play on the Crank.
When I first put the case together there was plenty of end play. Now there is not very much.
Is this normal as pistons and cylinders are added things tighten up?
when I push the flywheel in I set the dial indicator to 0 and then grab the fly wheel and pull it back.
I get a .006" while pulling but when I let go it settles at.005".
What is the correct measuring point under pressure or relaxed?
Should the flywheel just be pulled by hand or pried lightly with screw driver?
mrbubblehead
post Aug 19 2013, 07:10 PM
Twodollardoug
relaxed. .004 is the middle of the spec. do you have access to an assortment of shims?
- Lo-Fi Version Time is now: 25th November 2026 - 09:37 PM
