> Crank end play
jmargush
post Aug 19 2013, 06:08 PM
I am at the point of checking end play on the Crank.
When I first put the case together there was plenty of end play. Now there is not very much.
Is this normal as pistons and cylinders are added things tighten up?
when I push the flywheel in I set the dial indicator to 0 and then grab the fly wheel and pull it back.
I get a .006" while pulling but when I let go it settles at.005".
What is the correct measuring point under pressure or relaxed?
Should the flywheel just be pulled by hand or pried lightly with screw driver?
jmargush
post Aug 19 2013, 07:23 PM
I don't have a great assortment of shims. just what was in the engines I have which all seem to bee .011 - .014 and I seem to need thinner shims as I am close to .006 with one shim.
I will try the mallet method and Hopefully my FLAPS can get shims pretty quickly.
I would like to run the car on Sunday.
- Lo-Fi Version Time is now: 25th November 2026 - 09:37 PM
