| jmargush |
Aug 19 2013, 06:08 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 517 Joined: 8-June 04 From: Goshen, IN Member No.: 2,176 |
I am at the point of checking end play on the Crank.
When I first put the case together there was plenty of end play. Now there is not very much. Is this normal as pistons and cylinders are added things tighten up? when I push the flywheel in I set the dial indicator to 0 and then grab the fly wheel and pull it back. I get a .006" while pulling but when I let go it settles at.005". What is the correct measuring point under pressure or relaxed? Should the flywheel just be pulled by hand or pried lightly with screw driver? |
| jmargush |
Aug 20 2013, 04:45 AM
anyone know what size shims come in?
I measured last night with no shims and I get .023" end play. So .023 - .004=.019"/3 =.0063" Do they make shims that thin? Is it a concern that there is so little movement without any shims? |
jmargush Crank end play Aug 19 2013, 06:08 PM
r_towle Hit with a RUBBER mallet on the other end.
Read i... Aug 19 2013, 06:21 PM
mrbubblehead relaxed. .004 is the middle of the spec. do you ha... Aug 19 2013, 07:10 PM
r_towle The crank shaft under load will move the maximum a... Aug 19 2013, 07:15 PM
jmargush I don't have a great assortment of shims. jus... Aug 19 2013, 07:23 PM
r_towle Shims are to be found at specialty parts shops for... Aug 19 2013, 07:30 PM
jmargush Awesome
Brad isn't too far form me maybe he c... Aug 19 2013, 07:32 PM![]() ![]() |
Lo-Fi Version | Time is now: 25th November 2026 - 09:37 PM |
