Can the oil filter housing be removed with the engine in the car? |
tornik550 |
Aug 21 2013, 01:33 PM
Senior Member Group: Members Posts: 1,248 Joined: 29-January 07 From: Ohio Member No.: 7,486 Region Association: None |
As the title says- can the oil filter housing on a -4 be removed with the engine in the car. At least without major difficulty.
stugray |
Aug 21 2013, 06:03 PM
Advanced Member Group: Members Posts: 3,824 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None |
Here is a pic:
(IMG:http://www.914world.com/bbs2/uploads_offsite/i366.photobucket.com-10819-1377129833.1.jpg) You can see the pressed in valve "seat" that has the ball valve behind it. If you were to pull that out, the resulting hole appears to be ~.72" The "Boss" around that hole is ~1" I think you could pull out the seat and tap that hole to 3/4" Add a plug and youre done. (IMG:style_emoticons/default/confused24.gif) maybe? I would try it with the spare just for grins, but I dont want to ruin one just for the experiment. However I did try to see how much pressure it takes to open the valve but the pressure is so low it would be hard to test. I am guessing well below 10 PSI. Stu |
Lo-Fi Version | Time is now: 29th May 2024 - 05:40 AM |
