So I rode a 205HP VMax today...., Got me thinkin |
Tilly74 |
Aug 21 2013, 02:36 PM
Member Group: Members Posts: 96 Joined: 5-June 12 From: Springfield, MO Member No.: 14,522 Region Association: None |
Anyone ever put a larger displacement motorcycle engine in a 914? The VMax features a compact v-4 that makes 197bhp, 123 lb/ft torque and will peel your face off. Obviously it weights a lot less, but then I got to thinking about other options. (IMG:style_emoticons/default/idea.gif) We just got a Triumph Rocket III in stock and it's a 2.3 litre inline 3 cylinder. Makes 146 bhp and 163 lb/ft torque. Both motors are pretty compact and feature a shaft drive 6-speed transmission.
I think the transmission mating would be the most difficult, but what about adapting the motorcycle transmission somehow? I picture connecting the drive shaft to a rear differential of some sort. Or...if you could mate the shaft drive from the bike somehow to the 901, you could essentially have 30 different gearing combinations. All I would do is mount a hand clutch somewhere, maybe near where the rear brake is, and replace the heater lever with a simple hand shifter that would link to the bike's transmission. You could ALWAYS have the right gear, but you might need an extra hand or two, or a co-driver to manage the second transmission lol. One major benefit would be the lighter weight and the smaller radiator size, which might be able to be placed in a wheel well or somewhere besides the front trunk. This sounds crazy and over engineered to me, and probably not worth the effort, but I'm 27 and I'll hopefully be involved with teeners for the next 73 years (assuming I make it to 100, which is my goal), so I've got plenty of time to become a car building pioneer lol. Feel free to poke as many holes in this plan as you like. Won't hurt my feelings a bit. |
Tilly74 |
Aug 21 2013, 09:47 PM
I'm very aware of the weight difference between a car and a bike. My 914 came with a 67 hp, 99 lb/ft bus motor and I had a blast driving it. So I guess my question is: Other than flywheel weight, does it matter where the motor comes from? If a motor makes a certain amount of torque and hp, does it matter if its a type 4 or from a Yamaha? I've seen lots of money thrown into a type 4 that has a lot less than 200hp and 130lb/ft torque.
I do understand that a 914 wouldn't be the best choice for a motorcycle engine swap. Most motorcycle engines make 0 power below 5k, but some of these motors are different. The rocket III starts making power at 1200 rpm or something like that.. |
jhadler |
Aug 23 2013, 02:46 PM
Long term tinkerer... Group: Members Posts: 1,879 Joined: 7-April 03 From: Lyons, CO Member No.: 529 |
I'm very aware of the weight difference between a car and a bike. My 914 came with a 67 hp, 99 lb/ft bus motor and I had a blast driving it. So I guess my question is: Other than flywheel weight, does it matter where the motor comes from? If a motor makes a certain amount of torque and hp, does it matter if its a type 4 or from a Yamaha? I've seen lots of money thrown into a type 4 that has a lot less than 200hp and 130lb/ft torque. It's a lot more than just raw torque and hp. First off, it's about torque and hp at given rpms. Look at the torque curve of a four banger car motor, and compare that with the torque curve of a motorcycle engine that is rated for even twice the same power. You'll see that there is NOTHING near the bottom end where you need it to accelerate a car away from a standstill. Second, and more importantly, it's about how much load the drive-line is under when accelerating. The internals of the motorcycle engine don't need to be that beefy to withstand the load of accelerating even a 600 lb chassis. The internals of a car engine need to be a lot stronger to withstand the load of accelerating a 2000 lb chassis. This is why MC engines can be so small and light. The crank, rods, etc do not need to be very stout when they're really not subjected to much load. Those same internals for a car need to be a lot stronger as they are working against a much heavier load. -Josh |
Lo-Fi Version | Time is now: 6th June 2024 - 08:41 PM |
