> Bus heads?, Intake manifold bolt spacing
ThePaintedMan
post Aug 25 2013, 10:30 AM
Hey guys,
Just finishing up the prep on getting my spare motor back in the car. Came across something a little "fishy". So, I swapped over just about everything that was on my 1.7, and this engine is *supposed* to be a 1.8. Everything fits just fine, except for the intake manifolds and gaskets. There are 4 intake manifold studs, but the outer studs are about 3/8 inches further apart than on the 1.8. So much so, that the new 1.7/1.8 phenolic spacers that I have do not fit over the studs. I noticed that the previous owner had cut the spacers in half to make two separate pieces, for each intake port. They still didn't fit quite right though, and part of the spacer protrudes into the intake hole/bore.
I'm wondering if these are some kind of other Type 4 head, perhaps from a bus? Pictures to follow in a moment...
Dave_Darling
post Aug 25 2013, 01:27 PM
914 Idiot
I think the casting numbers are in the rocker box.
--DD
ThePaintedMan   Bus heads?   Aug 25 2013, 10:30 AM
euro911   Can you post the # on the heads? (gotta pull the t...   Aug 25 2013, 11:07 AM
ThePaintedMan   Hey Mark... Where are the casting numbers on the ...   Aug 25 2013, 12:52 PM
Dave_Darling   I think the casting numbers are in the rocker box....   Aug 25 2013, 01:27 PM
ThePaintedMan   It was under the valve cover, not the engine tin. ...   Aug 25 2013, 01:28 PM
ThePaintedMan   That site also lists 022-101-372G as a 2.0. I coul...   Aug 25 2013, 01:34 PM
euro911   That's weird :blink: :confused:   Aug 25 2013, 01:39 PM
ThePaintedMan   I know, right? Raby would know this one for sure. ...   Aug 25 2013, 01:45 PM
type47   How about the alignment with the holes on the inta...   Aug 25 2013, 01:47 PM
ThePaintedMan   The intake manifolds line up fine, from what I can...   Aug 25 2013, 01:52 PM
JamesM   The intake manifolds line up fine, from what I ca...   Aug 26 2013, 12:57 PM
ThePaintedMan   Well, I ended up installing them as-is with a gask...   Aug 26 2013, 11:46 AM
euro911   Well, I ended up installing them as-is with a gask...   Aug 26 2013, 12:19 PM
skeates   Was the mis-match the same on both heads? Could be...   Aug 26 2013, 01:10 PM
euro911   Was the mis-match the same on both heads? Could be...   Aug 26 2013, 01:31 PM
Cap'n Krusty   I have seen ONLY one 4 bolt intake manifold bolt p...   Aug 26 2013, 01:21 PM
euro911   I have seen ONLY one 4 bolt intake manifold bolt p...   Aug 26 2013, 01:33 PM
Cap'n Krusty   Yup. "Race track" looking exhaust ports...   Aug 26 2013, 01:55 PM
ThePaintedMan   Yeah I knew about the square exhaust ports on the ...   Aug 26 2013, 02:04 PM
r_towle   Could be the 2.0 liter heads that someone removed ...   Aug 26 2013, 08:11 PM
euro911   Looking at the pic, it looks like they're not ...   Aug 26 2013, 11:38 PM
ThePaintedMan   Yeah I had considered that they were 2.0 heads tha...   Aug 27 2013, 06:11 AM
r_towle   could have been re-drilled to the 2.0 liter outer ...   Aug 27 2013, 01:13 PM
FourBlades   The real question is, how does it run? :D John   Aug 27 2013, 05:56 PM
billh1963   That's the engine out of the Pink Panther...   Aug 27 2013, 06:04 PM
ThePaintedMan   It'll run, well, it'll be STARTED tomorrow...   Aug 27 2013, 10:00 PM
euro911   That's called paying your dues. Some day, you...   Aug 27 2013, 10:50 PM
ThePaintedMan   That's called paying your dues. Some day, you...   Aug 27 2013, 11:01 PM
r_towle   That's called paying your dues. Some day, yo...   Aug 28 2013, 10:57 AM
FourBlades   I did my entire blue car restoration on paving sto...   Aug 28 2013, 11:25 AM
- Lo-Fi Version Time is now: 2nd April 2026 - 01:06 PM
