> Aftermarket fuel pump, What are my best options?
saigon71
post Aug 25 2013, 03:55 PM
Car is a 74 2.0 D-Jet.
Put power to my original three port fuel pump today and it leaked like a sieve at the seam. All hose connections are good.
I would be fine switching to an aftermarket two port pump. I remember hearing about a Bosch pump on this site at NAPA for $31, so I did a search on 914world to find the link. Just checked NAPA and the same pump is now $186.
Found a "Hayg" on Ebay for $50. Ad says it will fit a 914. But it is ebay and a pump I never heard of.
Has anyone found a reasonable aftermarket replacement lately?
Thanks.
Bob
JawjaPorsche
post Aug 25 2013, 04:19 PM
GR Parts has Bosch for$156
http://www.gprparts.com/ShopByVehicle.epc?...ump&mode=PA
saigon71
post Aug 26 2013, 05:43 AM
QUOTE(JawjaPorsche @ Aug 25 2013, 06:19 PM) *
Thanks for the responses. After sleeping on it, I decided to go with a brand new two port Bosch pump from GPR. Free shipping!
One less thing to worry about when bombing around in a 40 year old car. (IMG:style_emoticons/default/biggrin.gif)
How do I re-plumb the fuel hoses going from a three port pump to a two port pump?
JawjaPorsche
post Aug 26 2013, 05:49 AM
QUOTE(saigon71 @ Aug 26 2013, 07:43 AM) *
On the return line, there is a Y connection where the fuel went back into the pump and the other to fuel tank. Just discard the Y connection and run return line back to the tank. No return line to fuel pump since you only have two ports.
The new fuel pump will have a smaller diameter than the three port pump. You are going to have to make some modifications on the bracket. I used an old Bosch coil bracket holder.
You will also need a different fuel filter than the one needed for the three port. The in port is bigger than the out port. I got mine from NAPA. Part Number 3274.
saigon71   Aftermarket fuel pump   Aug 25 2013, 03:55 PM
914itis   I have a barely used 2 port that I can part out wi...   Aug 25 2013, 04:15 PM
JawjaPorsche   GR Parts has Bosch for$156 http://www.gprpar...   Aug 25 2013, 04:19 PM
saigon71   GR Parts has Bosch for$156 http://www.gprpa...   Aug 26 2013, 05:43 AM
JawjaPorsche   [quote name='JawjaPorsche' post='1914911' date='A...   Aug 26 2013, 05:49 AM
76-914   Slits has the Ford? number for the same pump. Bout...   Aug 25 2013, 06:05 PM
hot_shoe914   I bought a 2 port from the local FLAPS for about 4...   Aug 26 2013, 06:18 AM
Mblizzard   I bought a 2 port from the local FLAPS for about ...   Aug 26 2013, 07:04 AM
The Cabinetmaker   NAPA part #N69133. Under 100 bucks at my local nap...   Aug 26 2013, 11:51 AM
JawjaPorsche   NAPA part #N69133. Under 100 bucks at my local na...   Aug 26 2013, 12:41 PM
SLITS   This is what NAPA was selling: http://www.914worl...   Aug 26 2013, 01:12 PM
The Cabinetmaker   Yep. Same as I have. I bought 2 before they raised...   Aug 26 2013, 01:25 PM
SLITS   Yep. Same as I have. I bought 2 before they raise...   Aug 26 2013, 02:23 PM
Mblizzard   Looking at the NAPA pump are there any specs? It ...   Aug 26 2013, 01:53 PM
JawjaPorsche   Looking at the NAPA pump are there any specs? It...   Aug 26 2013, 02:10 PM
The Cabinetmaker   One line from tank to filter, then to pump, then t...   Aug 26 2013, 02:14 PM
chad newton   What about a Holley red or blue pump with a regula...   Aug 26 2013, 05:42 PM
The Cabinetmaker   Holley makes a high pressure fuel injection pump?   Aug 26 2013, 06:01 PM
chad newton   Holley makes a high pressure fuel injection pump?...   Aug 26 2013, 06:16 PM
Cap'n Krusty   Operating system pressure is 30PSI, more or less, ...   Aug 26 2013, 06:20 PM
r_towle   OEM pump was 65 psi but I cannot recall the GPh. ...   Aug 26 2013, 08:03 PM
saigon71   Thanks for the instructions on the plumbing! ...   Aug 29 2013, 06:02 AM
JawjaPorsche   Thanks for the instructions on the plumbing...   Aug 29 2013, 06:10 AM
- Lo-Fi Version Time is now: 2nd August 2025 - 03:26 AM
