> Aftermarket fuel pump, What are my best options?
saigon71
post Aug 25 2013, 03:55 PM
Car is a 74 2.0 D-Jet.
Put power to my original three port fuel pump today and it leaked like a sieve at the seam. All hose connections are good.
I would be fine switching to an aftermarket two port pump. I remember hearing about a Bosch pump on this site at NAPA for $31, so I did a search on 914world to find the link. Just checked NAPA and the same pump is now $186.
Found a "Hayg" on Ebay for $50. Ad says it will fit a 914. But it is ebay and a pump I never heard of.
Has anyone found a reasonable aftermarket replacement lately?
Thanks.
Bob
chad newton
post Aug 26 2013, 05:42 PM
What about a Holley red or blue pump with a regulator? I don't know if any of us put out that kind of power to need that flow but could that be an option? What psi do webers run at?
saigon71   Aftermarket fuel pump   Aug 25 2013, 03:55 PM
914itis   I have a barely used 2 port that I can part out wi...   Aug 25 2013, 04:15 PM
JawjaPorsche   GR Parts has Bosch for$156 http://www.gprpar...   Aug 25 2013, 04:19 PM
saigon71   GR Parts has Bosch for$156 http://www.gprpa...   Aug 26 2013, 05:43 AM
JawjaPorsche   [quote name='JawjaPorsche' post='1914911' date='A...   Aug 26 2013, 05:49 AM
76-914   Slits has the Ford? number for the same pump. Bout...   Aug 25 2013, 06:05 PM
hot_shoe914   I bought a 2 port from the local FLAPS for about 4...   Aug 26 2013, 06:18 AM
Mblizzard   I bought a 2 port from the local FLAPS for about ...   Aug 26 2013, 07:04 AM
The Cabinetmaker   NAPA part #N69133. Under 100 bucks at my local nap...   Aug 26 2013, 11:51 AM
JawjaPorsche   NAPA part #N69133. Under 100 bucks at my local na...   Aug 26 2013, 12:41 PM
SLITS   This is what NAPA was selling: http://www.914worl...   Aug 26 2013, 01:12 PM
The Cabinetmaker   Yep. Same as I have. I bought 2 before they raised...   Aug 26 2013, 01:25 PM
SLITS   Yep. Same as I have. I bought 2 before they raise...   Aug 26 2013, 02:23 PM
Mblizzard   Looking at the NAPA pump are there any specs? It ...   Aug 26 2013, 01:53 PM
JawjaPorsche   Looking at the NAPA pump are there any specs? It...   Aug 26 2013, 02:10 PM
The Cabinetmaker   One line from tank to filter, then to pump, then t...   Aug 26 2013, 02:14 PM
chad newton   What about a Holley red or blue pump with a regula...   Aug 26 2013, 05:42 PM
The Cabinetmaker   Holley makes a high pressure fuel injection pump?   Aug 26 2013, 06:01 PM
chad newton   Holley makes a high pressure fuel injection pump?...   Aug 26 2013, 06:16 PM
Cap'n Krusty   Operating system pressure is 30PSI, more or less, ...   Aug 26 2013, 06:20 PM
r_towle   OEM pump was 65 psi but I cannot recall the GPh. ...   Aug 26 2013, 08:03 PM
saigon71   Thanks for the instructions on the plumbing! ...   Aug 29 2013, 06:02 AM
JawjaPorsche   Thanks for the instructions on the plumbing...   Aug 29 2013, 06:10 AM
- Lo-Fi Version Time is now: 2nd August 2025 - 03:37 AM
