> Bowed 914..., As Maxwell Smart would say, missed it by this much
mr914
post Aug 25 2013, 08:29 PM
914 Hillbilly
Lesson learned #11- before attempting this at home, get the alignment checked on a frame machine. I built custom door/chassis reinforcement bars before going on the rotisserie. Assuming that the PO had repaired the longitudinals correctly.
After 12 years, the car finally landed on the jack stands. As the original Dorris were thoroughly rusted out, I had replacement doors. Bolted the replacement doors on, and the don't fit. Bolted original doors on and they do with funky gaps....
Put the reinforcement bars on and the fit like I had built them.. (IMG:style_emoticons/default/huh.gif) looked at how the front strut upper plates were located. One has never moved based on factory tar, the other one had been moved 1/4-3/8"
Damn, why didn't I catch that years ago... (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/headbang.gif)
Did test assemble, top, doors gaskets. Car is square but the longs appear to be bowed, fortunately evenly.
Put the reinforcement bars on and they fit like I had built them.. (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/headbang.gif)
Based on the targa top fitment, it Looks like the car is bowed 1/4-3/8".
Door fitment (replacement doors) - front gap is good and even, the rear is 3/8" high at the body line (stack of 5 US Quarters).
Hung the original doors, drivers door is spot on, rusted at the bottom and evidence of a cut and re weld between the hinges. Damn-it, unbolted the doors, put them on the shelf in the basement and ignored them for 10+ years (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/headbang.gif)
Now, how to fix it....
1) bolt suspension on, ship to frame shop, have them tweak the body and align the suspension before reassembly. (There is a near local shop that all the local 914 people swear by). The advantage is, I can use my special tool (Louisville Slugger, that has never hit a ball) to roll the fenders to accommodate 15x7 w/195/60/15s
2) now that it is on jackstands, (800-1200# sand/weight) in the passenger compartment and let gravity do its thing over the winter, while I work on other details, engine, trans, etc...
Looking for better ideas, suggestions? (IMG:style_emoticons/default/drunk.gif)
What's pissing me off, is all the work and years on the rotisserie, I'm sure did not cause the bend/bow..
It's not that far off, not twisted, but definitely solid
mr914
post Aug 26 2013, 08:51 PM
914 Hillbilly
"Hung the original doors, drivers door is spot on, rusted at the bottom and evidence of a cut and re weld between the hinges" The original passenger door, the gaps are small at the bottom on both sides and large at the top on both sides. The original doors, open, close, latch just fine. The original doors arre too rusty, so I had moved on to replacement doors and thats where I found the problem.
I probbably did not cause the bow as the original doores had been mangled to appear to fit right. I was well aware of the warp issues with welding. And I made sure to take my time and allow the areas to cool
mr914   Bowed 914...   Aug 25 2013, 08:29 PM
mr914   US quarter measuring system   Aug 25 2013, 08:30 PM
mr914   :headbang:   Aug 25 2013, 08:31 PM
mr914   With a good door   Aug 25 2013, 08:32 PM
mr914   Front gap   Aug 25 2013, 08:33 PM
mr914   At least, withe the suspension on, I can use my sp...   Aug 25 2013, 08:46 PM
mr914   BTW. The white shell has been tested on three cars...   Aug 25 2013, 09:15 PM
sixnotfour   Is this 914 the Six you have ??, If so all the rep...   Aug 26 2013, 03:20 PM
Chris H.   rick918-s has a Celette bench with 914 fixtures. ...   Aug 26 2013, 03:36 PM
mr914   "Hung the original doors, drivers door is spo...   Aug 26 2013, 08:51 PM
rick 918-S   Wow! That this is twisted! I have plans ...   Aug 27 2013, 06:21 AM
bulitt   Thats a deal! :trophy:   Aug 27 2013, 06:25 AM
- Lo-Fi Version Time is now: 15th July 2025 - 10:24 AM
