| HalfMoon |
Aug 27 2013, 03:52 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 828 Joined: 13-November 12 From: Shenandoah Junction, WV Member No.: 15,144 Region Association: MidAtlantic Region |
Imagine my dismay when today I decided to open the dash (I was trouble shooting a fuel gauge not working-easy fix, PO had cut the wires at the tank for some reason), discovering a huge amount of loose wires. The PO had installed a completly different tach so I'm hoping alot of these wires (11) had a purpose for being disconnected. Vain hope most likely...
I did notice the brake warning light stays on all the time...and of course nothing else works (except the fuel gauge that I just hooked back up). The car is a v-8 converted teener so alot of stuff may be disconnected for that reason as well. The real problem is that I'm VERY color blind. I can read a schematic reasonably well if I know what color wires I'm looking at on the car, which brings us to the reason for this post! Could someone help me identify the loose wires I've numbered in the enclosed photograph? What color corresponds to the numbered wires? With that data I should be able to figure out what was supposed to go where and assimilate if it was disconnected for purpose. Wiring and color blindness can be a serious challenge, so any help is appreciated :-) David Oh and btw, if you click on the image and then click again you'll get a very close view |
| bulitt |
Aug 28 2013, 06:54 AM
Achtzylinder ![]() ![]() ![]() ![]() Group: Members Posts: 4,189 Joined: 2-October 11 Member No.: 13,632 Region Association: South East States |
Moonman- I happened to label the back of my cluster on my 73. Couldn't recall I did it, oldsheisers.
So here is a pic. ![]() On the speedo the wire coming out the bottom is white/green -------- On the tach the wires from left to right are- brown brown/black red and the wire coming out of the bottom of the tach is white/blue ----------- On the combo clockwise in pic from 1100pm red green brown the rest of your wires you should be able to determine from Jeffs diagram- black/blue=gauge lights |
HalfMoon 1973 loose wires behind the dash Aug 27 2013, 03:52 PM
Ferg 1. Red/white stripe
2. Green/red stripe
3. Brow... Aug 27 2013, 03:57 PM
HalfMoon :headbang:
1. Red/white stripe
2. Green/red str... Aug 27 2013, 04:03 PM
bulitt This may help
http://www.914world.com/bbs2/upload... Aug 27 2013, 04:05 PM
HalfMoon
This may help
http://www.914world.com/bbs2/uploa... Aug 27 2013, 04:35 PM
Jeff Bowlsby That diagram is for 1974 car... ;)
But it should ... Aug 27 2013, 05:12 PM
HalfMoon
But it should... Aug 27 2013, 07:03 PM
Jeff Bowlsby
[quote name='Jeff Bowlsby' post='1916154' date='A... Aug 28 2013, 07:49 AM
HalfMoon
Moonman- I happened to label the back of my clust... Aug 28 2013, 08:34 AM
Dave_Darling Note that the wires numbered 9, 10, and 11 are add... Aug 28 2013, 08:04 AM
HalfMoon
Note that the wires numbered 9, 10, and 11 are ad... Aug 28 2013, 08:29 AM
Jeff Bowlsby Actually...
The factory used different striping p... Aug 28 2013, 10:09 AM
HalfMoon
Actually...
The factory used different striping ... Aug 28 2013, 10:28 AM
Jeff Bowlsby This is really sad to see, you are going to have h... Aug 28 2013, 01:19 PM
bulitt
This is really sad to see, you are going to have ... Aug 28 2013, 02:47 PM
HalfMoon Sigh. Well I goofed around with the pod wires some... Aug 28 2013, 05:45 PM
HalfMoon
Sigh. Well I goofed around with the pod wires som... Aug 29 2013, 01:16 PM
bulitt David- I crawled up on the lift to look at mine-
... Aug 29 2013, 02:47 PM
HalfMoon
... Aug 29 2013, 03:47 PM
Jonathan Livesay
... Aug 29 2013, 04:11 PM
bulitt Got that David?
Number 4 hooks to both lights
6 to... Aug 29 2013, 04:48 PM
HalfMoon
Got that David?
6 t... Aug 29 2013, 06:08 PM
bulitt yes Aug 29 2013, 06:13 PM
HalfMoon :Qarl:
AWESOME!
It worked and now my former b... Aug 29 2013, 06:50 PM
HalfMoon Durnit! Just when I thought we had it nailed ... Aug 30 2013, 03:15 PM
Jonathan Livesay
Durnit! Just when I thought we had it nailed ... Aug 30 2013, 04:21 PM
HalfMoon
Durnit! Just when I thought we had it nailed... Aug 30 2013, 04:34 PM
Jonathan Livesay
[quote name='Jonathan Livesay' post='1918030' dat... Aug 30 2013, 05:31 PM
HalfMoon
[quote name='Jonathan Livesay' post='1918030' da... Aug 30 2013, 06:25 PM
HalfMoon Pretty sure I goofed
What say you'ze
Aug 30 2013, 07:41 PM
Jonathan Livesay
What say you'ze
Yup. Aug 30 2013, 08:25 PM
bulitt Yes, the one you are holding should go to the turn... Aug 31 2013, 06:21 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 01:18 PM |
