> 1973 loose wires behind the dash
HalfMoon
post Aug 27 2013, 03:52 PM
Imagine my dismay when today I decided to open the dash (I was trouble shooting a fuel gauge not working-easy fix, PO had cut the wires at the tank for some reason), discovering a huge amount of loose wires. The PO had installed a completly different tach so I'm hoping alot of these wires (11) had a purpose for being disconnected. Vain hope most likely...
I did notice the brake warning light stays on all the time...and of course nothing else works (except the fuel gauge that I just hooked back up). The car is a v-8 converted teener so alot of stuff may be disconnected for that reason as well.
The real problem is that I'm VERY color blind. I can read a schematic reasonably well if I know what color wires I'm looking at on the car, which brings us to the reason for this post!
Could someone help me identify the loose wires I've numbered in the enclosed photograph? What color corresponds to the numbered wires? With that data I should be able to figure out what was supposed to go where and assimilate if it was disconnected for purpose.
Wiring and color blindness can be a serious challenge, so any help is appreciated :-)
David
Oh and btw, if you click on the image and then click again you'll get a very close view
HalfMoon
post Aug 30 2013, 03:15 PM
Durnit! Just when I thought we had it nailed (IMG:style_emoticons/default/mad.gif)
The indicator lights we rigged up work, true; but unfortunately when I turn the headlights on both indicators come on at the dash and stay lite which is to say they aren't blinking, just on (and the blinkers themselves stay offm unless I turn them on).
As an aside, if I turn the car off with a blinker on, all the running lights come on (and it always did this).
So, now I'm stumped again. Why on earth would the turn signal dash idicators come on when the headlights are on?
Ugh.
Jonathan Livesay
post Aug 30 2013, 04:21 PM
QUOTE(HalfMoon @ Aug 30 2013, 02:15 PM) *
Ugh.
Did you use the blue white striped wire or the white blue striped wire?
HalfMoon   1973 loose wires behind the dash   Aug 27 2013, 03:52 PM
Ferg   1. Red/white stripe 2. Green/red stripe 3. Brow...   Aug 27 2013, 03:57 PM
HalfMoon   :headbang: 1. Red/white stripe 2. Green/red str...   Aug 27 2013, 04:03 PM
bulitt   This may help http://www.914world.com/bbs2/upload...   Aug 27 2013, 04:05 PM
HalfMoon   This may help http://www.914world.com/bbs2/uploa...   Aug 27 2013, 04:35 PM
Jeff Bowlsby   That diagram is for 1974 car... ;) But it should ...   Aug 27 2013, 05:12 PM
HalfMoon   That diagram is for 1974 car... ;) But it should...   Aug 27 2013, 07:03 PM
Jeff Bowlsby   [quote name='Jeff Bowlsby' post='1916154' date='A...   Aug 28 2013, 07:49 AM
bulitt   Moonman- I happened to label the back of my cluste...   Aug 28 2013, 06:54 AM
HalfMoon   Moonman- I happened to label the back of my clust...   Aug 28 2013, 08:34 AM
Dave_Darling   Note that the wires numbered 9, 10, and 11 are add...   Aug 28 2013, 08:04 AM
HalfMoon   Note that the wires numbered 9, 10, and 11 are ad...   Aug 28 2013, 08:29 AM
Jeff Bowlsby   Actually... The factory used different striping p...   Aug 28 2013, 10:09 AM
HalfMoon   Actually... The factory used different striping ...   Aug 28 2013, 10:28 AM
Jeff Bowlsby   This is really sad to see, you are going to have h...   Aug 28 2013, 01:19 PM
bulitt   This is really sad to see, you are going to have ...   Aug 28 2013, 02:47 PM
HalfMoon   Sigh. Well I goofed around with the pod wires some...   Aug 28 2013, 05:45 PM
HalfMoon   Sigh. Well I goofed around with the pod wires som...   Aug 29 2013, 01:16 PM
bulitt   David- I crawled up on the lift to look at mine- ...   Aug 29 2013, 02:47 PM
HalfMoon   David- I crawled up on the lift to look at mine- ...   Aug 29 2013, 03:47 PM
Jonathan Livesay   David- I crawled up on the lift to look at mine- ...   Aug 29 2013, 04:11 PM
bulitt   Got that David? Number 4 hooks to both lights 6 to...   Aug 29 2013, 04:48 PM
HalfMoon   Got that David? Number 4 hooks to both lights 6 t...   Aug 29 2013, 06:08 PM
bulitt   yes   Aug 29 2013, 06:13 PM
HalfMoon   :Qarl: AWESOME! It worked and now my former b...   Aug 29 2013, 06:50 PM
HalfMoon   Durnit! Just when I thought we had it nailed ...   Aug 30 2013, 03:15 PM
Jonathan Livesay   Durnit! Just when I thought we had it nailed ...   Aug 30 2013, 04:21 PM
HalfMoon   Durnit! Just when I thought we had it nailed...   Aug 30 2013, 04:34 PM
Jonathan Livesay   [quote name='Jonathan Livesay' post='1918030' dat...   Aug 30 2013, 05:31 PM
HalfMoon   [quote name='Jonathan Livesay' post='1918030' da...   Aug 30 2013, 06:25 PM
HalfMoon   Pretty sure I goofed What say you'ze   Aug 30 2013, 07:41 PM
Jonathan Livesay   Pretty sure I goofed What say you'ze Yup.   Aug 30 2013, 08:25 PM
bulitt   Yes, the one you are holding should go to the turn...   Aug 31 2013, 06:21 AM
- Lo-Fi Version Time is now: 2nd April 2026 - 01:21 PM
