Difference between 110mm and 108mm |
chad newton |
Aug 30 2013, 07:04 PM
Member Group: Members Posts: 110 Joined: 26-August 11 From: behind the red curtain Member No.: 13,491 Region Association: None |
What is the difference between 110 and 108 stub axles and transmission stubs? Educate me guys. One us us has some parts for me but says they are 110mm 4 bolts 2 pins.
Mike Bellis |
Aug 31 2013, 11:40 AM
I've never heard of 110mm. (IMG:style_emoticons/default/confused24.gif)
I have 100mm I have 108mm I used to have 94mm My 108mm 930 CV's use 10mm bolts. My 108mm 911 CV's use 10mm bolts. My 100mm 944 CV's use 8mm bolts. |
Luke M |
Aug 31 2013, 12:15 PM
Senior Member Group: Members Posts: 1,374 Joined: 8-February 05 From: WNY Member No.: 3,574 Region Association: North East States |
I've never heard of 110mm. (IMG:style_emoticons/default/confused24.gif) I have 100mm I have 108mm I used to have 94mm My 108mm 930 CV's use 10mm bolts. My 108mm 911 CV's use 10mm bolts. My 100mm 944 CV's use 8mm bolts. I just checked a few threads on the bird board. Looks like the 110 mm flange is used with a 108 mm cv joint. It could be that the flanges and stub axles run a few mm's larger then the cv joints it self which is causing all of the confusion. So based on that I have 108 mm stubs and trans flanges then. |
Mark Henry |
Aug 31 2013, 12:42 PM
I've never heard of 110mm. (IMG:style_emoticons/default/confused24.gif) I have 100mm I have 108mm I used to have 94mm My 108mm 930 CV's use 10mm bolts. My 108mm 911 CV's use 10mm bolts. My 100mm 944 CV's use 8mm bolts. I just checked a few threads on the bird board. Looks like the 110 mm flange is used with a 108 mm cv joint. It could be that the flanges and stub axles run a few mm's larger then the cv joints it self which is causing all of the confusion. So based on that I have 108 mm stubs and trans flanges then. (IMG:style_emoticons/default/agree.gif) No such thing as a "110mm flange" it is a "flange for a 108mm CV with coarse splines". You do have to watch out for the 108mm early flange (these are off of 1969 and earlier) and are for the weak diff with the tit bolts. They seem to bolt up but are dimensionality incorrect. Half way down this page of Eric's post I tell you exactly what new CV's work and there are links to the bird with more info on CV's http://www.914world.com/bbs2/index.php?sho...91963&st=20 |
Lo-Fi Version | Time is now: 1st June 2024 - 05:49 PM |
