> Going to ad a front oil cooler- need help
tornik550
post Aug 31 2013, 07:56 PM
I am finally going to bite the bullet and install a front oil cooler. I have searched and searched and on this topic there is a bit too much info and hard to sort through all the posts. I have a few basic questions and I was hoping that someone could help or point me in the direction. All the rest seemed pretty straight forward.
I plan on using a sandwich plate (with plugged intermediate plate). I have a 4 cyl 2258. For the most part, the car is used for driving around and rare auto x. I have a schadek 26mm pump however I also have a 30mm that isnt installed yet- I plan on installing the schadek 30mm pump when I install the new cooler.
Questions-
1. Is it ok to use a sandwich plate for a front oil cooler? If ok- can someone point me in the direction of which one to buy?
2. Is it ok to use -8AN lines (steel braided)?
3. What is the general consensus on the most cost effective cooler for up front?
tornik550
post Aug 31 2013, 09:11 PM
How about this one?
Setrab- 16inches wide, 3 inches tall and 2 deep
http://www.ebay.com/itm/271200794472?ssPag...984.m1423.l2649
tornik550   Going to ad a front oil cooler- need help   Aug 31 2013, 07:56 PM
kg6dxn   I don't know about a sandwich plate. -8 lines...   Aug 31 2013, 08:18 PM
brant   an10 minimum an12 recommended. what size are the ...   Aug 31 2013, 08:40 PM
tornik550   an10 minimum an12 recommended. what size are the...   Aug 31 2013, 08:48 PM
tornik550   How about this one? Setrab- 16inches wide, 3 ...   Aug 31 2013, 09:11 PM
brp986s   I suggest you reconsider the whole front mount ide...   Aug 31 2013, 09:26 PM
tornik550   I suggest you reconsider the whole front mount id...   Aug 31 2013, 09:30 PM
Randal   I am finally going to bite the bullet and install...   Aug 31 2013, 09:55 PM
Cap'n Krusty   "A "must"? Why not plain rubber pu...   Aug 31 2013, 10:55 PM
Mark Henry   "A "must"? Why not plain rubber p...   Aug 31 2013, 11:15 PM
Randal   "A "must"? Why not plain rubber p...   Sep 1 2013, 08:42 AM
Elliot Cannon   The engine in my car is about the same as yours bu...   Sep 1 2013, 12:18 AM
tornik550   The engine in my car is about the same as yours b...   Sep 1 2013, 08:15 AM
type47   When I bought my orange car, it came with this Ear...   Sep 1 2013, 09:01 AM
tornik550   When I bought my orange car, it came with this Ea...   Sep 1 2013, 09:08 AM
type47   What type of oil pump do you have? stock, maybe ...   Sep 1 2013, 09:14 AM
tornik550   What type of oil pump do you have? stock, maybe...   Sep 1 2013, 09:35 AM
type47   Is your oil pressure ok? yes   Sep 1 2013, 09:43 AM
tornik550   What type of oil pump do you have? stock, maybe...   Sep 1 2013, 09:51 AM
tornik550   So I have been searching for oil line routing to t...   Sep 1 2013, 12:06 PM
Randal   So I have been searching for oil line routing to ...   Sep 1 2013, 12:32 PM
tornik550   So I have been searching for oil line routing to...   Sep 1 2013, 12:35 PM
Elliot Cannon   Oil cooler lines inside the car will make it reall...   Sep 1 2013, 12:44 PM
tornik550   So I just changed over from my snow plow air dam t...   Sep 1 2013, 07:02 PM
ConeDodger   Probably allows the factory flaps to create the lo...   Sep 1 2013, 07:06 PM
tornik550   Probably allows the factory flaps to create the l...   Sep 1 2013, 07:11 PM
Elliot Cannon   The oil cooler lines on the Yellow Zonker ran unde...   Sep 1 2013, 11:58 PM
brant   My black car is also routed close to the yellow si...   Sep 2 2013, 05:21 AM
- Lo-Fi Version Time is now: 2nd April 2026 - 01:14 PM
