| tornik550 |
Aug 31 2013, 07:56 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,248 Joined: 29-January 07 From: Ohio Member No.: 7,486 Region Association: None |
I am finally going to bite the bullet and install a front oil cooler. I have searched and searched and on this topic there is a bit too much info and hard to sort through all the posts. I have a few basic questions and I was hoping that someone could help or point me in the direction. All the rest seemed pretty straight forward.
I plan on using a sandwich plate (with plugged intermediate plate). I have a 4 cyl 2258. For the most part, the car is used for driving around and rare auto x. I have a schadek 26mm pump however I also have a 30mm that isnt installed yet- I plan on installing the schadek 30mm pump when I install the new cooler. Questions- 1. Is it ok to use a sandwich plate for a front oil cooler? If ok- can someone point me in the direction of which one to buy? 2. Is it ok to use -8AN lines (steel braided)? 3. What is the general consensus on the most cost effective cooler for up front? |
| Cap'n Krusty |
Aug 31 2013, 10:55 PM
Cap'n Krusty ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,794 Joined: 24-June 04 From: Santa Maria, CA Member No.: 2,246 Region Association: Central California |
"A "must"? Why not plain rubber pushloc hose? Worked for racers I know for years. Less expensive, pretty much failsafe, easier to work with, and you're not paying for the bling.
The Cap'n |
| Mark Henry |
Aug 31 2013, 11:15 PM
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada |
"A "must"? Why not plain rubber pushloc hose? Worked for racers I know for years. Less expensive, pretty much failsafe, easier to work with, and you're not paying for the bling. The Cap'n (IMG:style_emoticons/default/agree.gif) I've used Parker pushloc for 25 years and I've never had a failure. ....but I do "sort of" disagree with the "plain rubber pushloc hose" statement. Parker pushloc is a system, you must use their barb fittings and no clamps. I will never use the el'cheapo oil hose with the garden hose barbs and clamps. |
tornik550 Going to ad a front oil cooler- need help Aug 31 2013, 07:56 PM
kg6dxn I don't know about a sandwich plate.
-8 lines... Aug 31 2013, 08:18 PM
brant an10 minimum
an12 recommended.
what size are the ... Aug 31 2013, 08:40 PM
tornik550
an10 minimum
an12 recommended.
what size are the... Aug 31 2013, 08:48 PM
tornik550 How about this one?
Setrab- 16inches wide, 3 ... Aug 31 2013, 09:11 PM
brp986s I suggest you reconsider the whole front mount ide... Aug 31 2013, 09:26 PM
tornik550
I suggest you reconsider the whole front mount id... Aug 31 2013, 09:30 PM
Randal
I am finally going to bite the bullet and install... Aug 31 2013, 09:55 PM
Randal
"A "must"? Why not plain rubber p... Sep 1 2013, 08:42 AM
Elliot Cannon The engine in my car is about the same as yours bu... Sep 1 2013, 12:18 AM
tornik550
The engine in my car is about the same as yours b... Sep 1 2013, 08:15 AM
type47 When I bought my orange car, it came with this Ear... Sep 1 2013, 09:01 AM
tornik550
When I bought my orange car, it came with this Ea... Sep 1 2013, 09:08 AM
type47
What type of oil pump do you have?
stock, maybe ... Sep 1 2013, 09:14 AM
tornik550
stock, maybe... Sep 1 2013, 09:35 AM
type47
Is your oil pressure ok?
yes Sep 1 2013, 09:43 AM
tornik550
stock, maybe... Sep 1 2013, 09:51 AM
tornik550 So I have been searching for oil line routing to t... Sep 1 2013, 12:06 PM
Randal
So I have been searching for oil line routing to ... Sep 1 2013, 12:32 PM
tornik550
So I have been searching for oil line routing to... Sep 1 2013, 12:35 PM
Elliot Cannon Oil cooler lines inside the car will make it reall... Sep 1 2013, 12:44 PM
tornik550 So I just changed over from my snow plow air dam t... Sep 1 2013, 07:02 PM
ConeDodger Probably allows the factory flaps to create the lo... Sep 1 2013, 07:06 PM
tornik550
Probably allows the factory flaps to create the l... Sep 1 2013, 07:11 PM
Elliot Cannon The oil cooler lines on the Yellow Zonker ran unde... Sep 1 2013, 11:58 PM
brant My black car is also routed close to the yellow si... Sep 2 2013, 05:21 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 01:13 PM |
