| tornik550 |
Aug 31 2013, 07:56 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,248 Joined: 29-January 07 From: Ohio Member No.: 7,486 Region Association: None |
I am finally going to bite the bullet and install a front oil cooler. I have searched and searched and on this topic there is a bit too much info and hard to sort through all the posts. I have a few basic questions and I was hoping that someone could help or point me in the direction. All the rest seemed pretty straight forward.
I plan on using a sandwich plate (with plugged intermediate plate). I have a 4 cyl 2258. For the most part, the car is used for driving around and rare auto x. I have a schadek 26mm pump however I also have a 30mm that isnt installed yet- I plan on installing the schadek 30mm pump when I install the new cooler. Questions- 1. Is it ok to use a sandwich plate for a front oil cooler? If ok- can someone point me in the direction of which one to buy? 2. Is it ok to use -8AN lines (steel braided)? 3. What is the general consensus on the most cost effective cooler for up front? |
| tornik550 |
Sep 1 2013, 12:06 PM
So I have been searching for oil line routing to the front cooler. I am planning on running stainless braided lines under the passenger rocker. All of the pictures that I can find involve running the lines partially in the back and front of the passenger cabin. Is there any way to avoid running the lines through the passenger cabin while still running them under the rocker panels? I really don't mind routing the lines in the back of the passenger compartment however I would like to avoid running them through the passenger footwell.
| Randal |
Sep 1 2013, 12:32 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,446 Joined: 29-May 03 From: Los Altos, CA Member No.: 750 |
So I have been searching for oil line routing to the front cooler. I am planning on running stainless braided lines under the passenger rocker. All of the pictures that I can find involve running the lines partially in the back and front of the passenger cabin. Is there any way to avoid running the lines through the passenger cabin while still running them under the rocker panels? I really don't mind routing the lines in the back of the passenger compartment however I would like to avoid running them through the passenger footwell. Under or on the side of the car, but wouldn't recommend that approach. |
| tornik550 |
Sep 1 2013, 12:35 PM
So I have been searching for oil line routing to the front cooler. I am planning on running stainless braided lines under the passenger rocker. All of the pictures that I can find involve running the lines partially in the back and front of the passenger cabin. Is there any way to avoid running the lines through the passenger cabin while still running them under the rocker panels? I really don't mind routing the lines in the back of the passenger compartment however I would like to avoid running them through the passenger footwell. Under or on the side of the car, but wouldn't recommend that approach. Ok- It scares me a bit to have the lines outside so is it safe to have oil lines running under the passengers feet? Is it ok to run them under the carpet? |
tornik550 Going to ad a front oil cooler- need help Aug 31 2013, 07:56 PM
kg6dxn I don't know about a sandwich plate.
-8 lines... Aug 31 2013, 08:18 PM
brant an10 minimum
an12 recommended.
what size are the ... Aug 31 2013, 08:40 PM
tornik550
an10 minimum
an12 recommended.
what size are the... Aug 31 2013, 08:48 PM
tornik550 How about this one?
Setrab- 16inches wide, 3 ... Aug 31 2013, 09:11 PM
brp986s I suggest you reconsider the whole front mount ide... Aug 31 2013, 09:26 PM
tornik550
I suggest you reconsider the whole front mount id... Aug 31 2013, 09:30 PM
Randal
I am finally going to bite the bullet and install... Aug 31 2013, 09:55 PM
Cap'n Krusty "A "must"? Why not plain rubber pu... Aug 31 2013, 10:55 PM
Mark Henry
"A "must"? Why not plain rubber p... Aug 31 2013, 11:15 PM
Randal
"A "must"? Why not plain rubber p... Sep 1 2013, 08:42 AM
Elliot Cannon The engine in my car is about the same as yours bu... Sep 1 2013, 12:18 AM
tornik550
The engine in my car is about the same as yours b... Sep 1 2013, 08:15 AM
type47 When I bought my orange car, it came with this Ear... Sep 1 2013, 09:01 AM
tornik550
When I bought my orange car, it came with this Ea... Sep 1 2013, 09:08 AM
type47
What type of oil pump do you have?
stock, maybe ... Sep 1 2013, 09:14 AM
tornik550
stock, maybe... Sep 1 2013, 09:35 AM
type47
Is your oil pressure ok?
yes Sep 1 2013, 09:43 AM
tornik550
stock, maybe... Sep 1 2013, 09:51 AM
Elliot Cannon Oil cooler lines inside the car will make it reall... Sep 1 2013, 12:44 PM
tornik550 So I just changed over from my snow plow air dam t... Sep 1 2013, 07:02 PM
ConeDodger Probably allows the factory flaps to create the lo... Sep 1 2013, 07:06 PM
tornik550
Probably allows the factory flaps to create the l... Sep 1 2013, 07:11 PM
Elliot Cannon The oil cooler lines on the Yellow Zonker ran unde... Sep 1 2013, 11:58 PM
brant My black car is also routed close to the yellow si... Sep 2 2013, 05:21 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 01:24 PM |
