shift shaft conical set screws, how tight? |
malcolm2 |
Sep 2 2013, 09:51 AM
Advanced Member Group: Members Posts: 2,747 Joined: 31-May 11 From: Nashville Member No.: 13,139 Region Association: South East States |
Ok to avoid the "screw won't come out" issue again, let me ask.....What is the object here? I am installing the long under the engine, curved shift shaft on my 75, side shift tranny. The coupling by the fire wall gives me no issues. However the one at the shift console does.
I assume you want to screw in the set screw until the shaft has NO PLAY, correct? It ended up pretty tight, but I have no play. I guess it could it have wiggled around over the years and increased the size of the hole in the shaft. Thoughts?? |
cwpeden |
Sep 2 2013, 10:24 AM
Great White North, huh? Group: Members Posts: 916 Joined: 20-August 06 From: Victoria BC Member No.: 6,693 Region Association: Canada |
The fact that its a taper is what's locking it in there. Its a self locking taper. Think of a Morse taper on a big drill machine or the tail stock in a lathe. I just through the tool in there by hand and need a hammer and wedge to get it out.
You may think its not that tight but then its a @@#t too get out. Just did it twice this weekend myself. Make sure the hole in the shaft is clean. If there is grease or crap in there it may feel tight but its just bottoming out on the crap and not the sides of the hole. This goes back to me doing it twice this weekend.... |
Lo-Fi Version | Time is now: 7th June 2024 - 03:40 PM |
