Stud remover, Yes, I know you can buy this from Snap On |
worn |
Sep 10 2013, 09:56 AM
can't remember Group: Members Posts: 3,164 Joined: 3-June 11 From: Madison, WI Member No.: 13,152 Region Association: Upper MidWest |
I wanted to pull the studs from a transmission case so I wouldn't poke my eye out with the darn things and while it wears the magnesium it also shows when there isn't any really left in the threads. there - the excuses, version 1.
So I got 1 bolt and 1 nut and set the lathe for stun, er taper cut. The nut and the bolt are tapered so there is a countersink in the large nut and a fly-head screw look to the bolt. BTW the nut is a loose fit over the bolt - they aren't matched. While I was at it I drilled straight into the top of the bolt to allow for thread tapping. Off the lathe, the hole in the top of the bolt was tapped to fit the stud - this was 8 mm, but I am gunning for 911 head studs eventually. I used a slotting wheel on the angle grinder to make an X cut down the length. Then I added a nut that does fit the bolt. Whoops, didn't go down far enough so another loose nut was added as a spacer. This is what it looked like in action. Unfortunately I pinned a nut to allow for wrenching so it doesn't come apart and the pix aren't so great, but here is the stud. |
sixnotfour |
Sep 10 2013, 02:45 PM
914 Wizard Group: Members Posts: 10,436 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
Two nuts tighten agianst each other works good too.
I do have the old snap-on stud and dowel remover, way better than the one they sell now IMHO. |
Nine_14 |
Sep 10 2013, 02:53 PM
Member Group: Members Posts: 311 Joined: 30-August 12 From: Germany Member No.: 14,873 Region Association: Germany |
Two nuts tighten agianst each other works good too. (IMG:style_emoticons/default/agree.gif) Why doing it easily when it also works complicated (IMG:style_emoticons/default/dry.gif) |
Lo-Fi Version | Time is now: 11th June 2024 - 08:13 AM |
