I wanted to pull the studs from a transmission case so I wouldn't poke my eye out with the darn things and while it wears the magnesium it also shows when there isn't any really left in the threads. there - the excuses, version 1.
So I got 1 bolt and 1 nut and set the lathe for stun, er taper cut.
The nut and the bolt are tapered so there is a countersink in the large nut and a fly-head screw look to the bolt. BTW the nut is a loose fit over the bolt - they aren't matched.
While I was at it I drilled straight into the top of the bolt to allow for thread tapping.
Off the lathe, the hole in the top of the bolt was tapped to fit the stud - this was 8 mm, but I am gunning for 911 head studs eventually. I used a slotting wheel on the angle grinder to make an X cut down the length. Then I added a nut that does fit the bolt. Whoops, didn't go down far enough so another loose nut was added as a spacer. This is what it looked like in action.
Unfortunately I pinned a nut to allow for wrenching so it doesn't come apart and the pix aren't so great, but here is the stud.
