vacuum advance stuck?, can't get it to move by sucking on it |
turk22 |
Sep 15 2013, 11:03 AM
Treetop Flyer Group: Members Posts: 735 Joined: 27-July 12 From: Cincinnati OH Member No.: 14,725 Region Association: Upper MidWest |
(IMG:style_emoticons/default/dry.gif)
I'm in the process of installing the Pertronix ignition, but before I do, I wanted to A: confirm the advance was working B: regarding McMarks thread, make sure I didn't have interference with the little advance needle While removing the points, I see a little movement (very little) of the plate. But when hooking a hose up, and sucking on it, I'm able to get any movement at all. How freely should the plate move (how much vacuum is needed to get it to move? How much movement should there be in the plate? Is there a way to lubricate the plate, without dismantling the vacuum advance? (nervous enough just having removed the distributor) (IMG:style_emoticons/default/blink.gif) Thx, Turk |
914_teener |
Sep 15 2013, 11:55 AM
914 Guru Group: Members Posts: 5,205 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California |
That plate is jacked up, and needs to be cleaned.
The arm should easily move by suction. If not ....you need to rebuild it or replace the diaphragm canister. This will cause a vacuum leak. |
Lo-Fi Version | Time is now: 9th June 2024 - 06:21 PM |
