vacuum advance stuck?, can't get it to move by sucking on it |
turk22 |
Sep 15 2013, 11:03 AM
Treetop Flyer Group: Members Posts: 735 Joined: 27-July 12 From: Cincinnati OH Member No.: 14,725 Region Association: Upper MidWest |
(IMG:style_emoticons/default/dry.gif)
I'm in the process of installing the Pertronix ignition, but before I do, I wanted to A: confirm the advance was working B: regarding McMarks thread, make sure I didn't have interference with the little advance needle While removing the points, I see a little movement (very little) of the plate. But when hooking a hose up, and sucking on it, I'm able to get any movement at all. How freely should the plate move (how much vacuum is needed to get it to move? How much movement should there be in the plate? Is there a way to lubricate the plate, without dismantling the vacuum advance? (nervous enough just having removed the distributor) (IMG:style_emoticons/default/blink.gif) Thx, Turk |
r_towle |
Sep 15 2013, 01:25 PM
Custom Member Group: Members Posts: 24,591 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
Pull the c clip off the arm, detach the arm, see of the plates move freely....probably not.
Btw, this is a whole lot easier if you just remove the clamp nut Ann washer, then pull the unit out, work on it on the bench. Remember which way it is positioned.....the bottom tooth can only fit on way, so just remember where it was facing for timing it to get it started before you use a timing gun. For grease, I use wheel bearing grease. Remove the plates, remove the little clip that goes around both plates, remove the little ball in there, don't lose it, don't shoot it across the room, move slowly and work on a towel or rag so that ball can't get away from you. Then clean the plates off, they do come apart once the clip is off, but it's probably a tight fit. Don't damage the copper wire, just lay them open and clean them Smear both mating surfaces with grease, then the ball. Put the clip back on and test to make sure they now move freely. Rich |
Lo-Fi Version | Time is now: 9th June 2024 - 06:37 PM |
