vacuum advance stuck?, can't get it to move by sucking on it |
turk22 |
Sep 15 2013, 11:03 AM
Treetop Flyer Group: Members Posts: 735 Joined: 27-July 12 From: Cincinnati OH Member No.: 14,725 Region Association: Upper MidWest |
(IMG:style_emoticons/default/dry.gif)
I'm in the process of installing the Pertronix ignition, but before I do, I wanted to A: confirm the advance was working B: regarding McMarks thread, make sure I didn't have interference with the little advance needle While removing the points, I see a little movement (very little) of the plate. But when hooking a hose up, and sucking on it, I'm able to get any movement at all. How freely should the plate move (how much vacuum is needed to get it to move? How much movement should there be in the plate? Is there a way to lubricate the plate, without dismantling the vacuum advance? (nervous enough just having removed the distributor) (IMG:style_emoticons/default/blink.gif) Thx, Turk |
r_towle |
Sep 16 2013, 05:44 AM
Custom Member Group: Members Posts: 24,591 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
He is troubleshooting.
Pull the hose off the distributor and plug the line. See if it helps your Idle issue. Simple test, then you can decide if you need to find and replace the canister. Rich |
cwpeden |
Sep 16 2013, 09:18 AM
Great White North, huh? Group: Members Posts: 916 Joined: 20-August 06 From: Victoria BC Member No.: 6,693 Region Association: Canada |
He is troubleshooting. Pull the hose off the distributor and plug the line. See if it helps your Idle issue. Simple test, then you can decide if you need to find and replace the canister. Rich Make sure to check the other end of the hose too. I replaced a Vac can just to find out it was the other end of the hose that was leaking. (IMG:style_emoticons/default/headbang.gif) and throttle body gasket..and intake runners...and passenger side intake gasket. |
Lo-Fi Version | Time is now: 9th June 2024 - 06:29 PM |
