| jimkelly |
Sep 16 2013, 12:45 PM
Delaware USA ![]() ![]() ![]() ![]() Group: Members Posts: 4,969 Joined: 5-August 04 From: Delaware, USA Member No.: 2,460 Region Association: MidAtlantic Region |
wiring my v8
and tell me what I have wrong or missing. my bad for never labeling the wires (IMG:style_emoticons/default/headbang.gif) distributor is msd 8360 but you guys are smart (IMG:style_emoticons/default/smoke.gif) and yes - I better connect that oil guage line or I will have a mess on my hands. Attached thumbnail(s) |
| Spoke |
Sep 16 2013, 02:13 PM
Jerry ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,419 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None
Page 5: Red wire from harness is 12V power to coil and distributor.
Page 6: Blue wire is from original voltage regulator. Unless that goes to a sender on the new alternator, you don't need this. You also don't need the original voltage regulator. Page 6: The red wire to the battery doesn't look good at that terminal block. Also you need some sort of rubber cover for that connection. Touching that to any grounded point will result in fireworks as there is nothing to limit the current from the battery except the wire. Page 6: Where does the blue wire go? |
jimkelly making some progress on my sbc 307 V8 car Sep 16 2013, 12:45 PM
3d914 IIRC the yellow wire goes to the positive side of ... Sep 16 2013, 01:01 PM
jimkelly thank you - I am editing my collage as we go.
jim Sep 16 2013, 01:05 PM
jimkelly spoke
I am pretty sure my ignition switch was par... Sep 16 2013, 02:30 PM
jmmotorsports
spoke
I am pretty sure my ignition switch was pa... Sep 17 2013, 04:15 AM
chads74
spoke
I am pretty sure my ignition switch was p... Sep 17 2013, 06:19 AM
jimkelly spoke
image 6 - the blue wire loops around and co... Sep 16 2013, 07:31 PM
Spoke
spoke
image 6 - the blue wire loops around and c... Sep 17 2013, 06:49 AM
dwillouby I dont use the relay board. You need a switched 12... Sep 17 2013, 06:42 AM
jimkelly I was thinking that since it seems to be the only ... Sep 17 2013, 07:03 AM
jimkelly finally going to put my crimper and heat shrink to... Sep 17 2013, 08:01 AM
jimkelly starter, shift linkage, gear oil, coolant fill nec... Sep 20 2013, 12:45 PM
76-914 Jim, are you doing this and the Suby conversion or... Sep 20 2013, 02:19 PM
jimkelly I simply want to get the 1972 V8 running and funct... Sep 20 2013, 03:24 PM
jimkelly just goofing around, since I already have a bar th... Sep 21 2013, 08:34 AM
zambezi yes they grind better and produce less heat. Easi... Sep 21 2013, 12:31 PM
jimkelly engine bay shift rod done : )
40.75"
it is ... Sep 21 2013, 01:15 PM
jimkelly some random pics Sep 22 2013, 11:22 AM
kg6dxn Your lower spring perch is upside down... :(
http... Sep 22 2013, 07:17 PM
jimkelly thanks for that!!!
jim Sep 22 2013, 07:45 PM
jimkelly don't be an idiot like me.
anyway, one flippe... Sep 23 2013, 07:41 AM
76-914 Is that a "red" ground wire? <_< Sep 23 2013, 03:04 PM
jimkelly from the relay board to the body? yes. I will ch... Sep 25 2013, 09:27 AM
jimkelly also - before, I had the pos from alt running to p... Sep 25 2013, 09:35 AM
kg6dxn
also - before, I had the pos from alt running to ... Sep 25 2013, 09:01 PM
jimkelly mike - I will get those wires buttoned up - thanks... Sep 26 2013, 09:34 AM
jimkelly guess i'll run the coolant lines today. the 2... Sep 29 2013, 08:25 AM
jimkelly well, not sure I like the relatively short 90 degr... Sep 29 2013, 03:14 PM
bulitt I may have to get one of those 90's. Sep 29 2013, 06:33 PM
jimkelly since the only electrical connector I have, that h... Sep 30 2013, 07:32 AM
jimkelly rcvd the 90 degree tube today - looks good. Oct 2 2013, 09:18 AM
andys Much nicer with that aluminum 90!
Andys Oct 2 2013, 09:26 AM
speed metal army Hey Jim, weather pack electrical connectors are a ... Oct 2 2013, 10:05 PM
jimkelly well, my car had a big gap, at top, between the dr... Oct 7 2013, 11:41 AM
JRust Yeah the aluminum 90% was a good move. I didn... Oct 7 2013, 08:11 PM
jimkelly well two issues.
I need to either come up with a ... Oct 9 2013, 01:12 PM
JRust The big washer with the groove goes on the bottom ... Oct 9 2013, 03:17 PM
jimkelly I have been searching and have yet to find a pic o... Oct 9 2013, 04:57 PM
JRust
I have been searching and have yet to find a pic ... Oct 10 2013, 07:20 AM
jimkelly instead of this jumble of parts, I am thinking of ... Oct 10 2013, 06:29 AM
bulitt I'm thinking you will break your trans ears of... Oct 10 2013, 06:50 AM
jimkelly for engine mounts, found washers that fit perfectl... Oct 10 2013, 07:34 AM
Chris H. Hijack but this exhaust setup is AWESOME
That... Oct 10 2013, 09:43 AM
jimkelly good point. behind trans is where the most space ... Oct 10 2013, 09:51 AM
mittelmotor I like the 2-in/2-out approach as well. Keeps the ... Oct 10 2013, 01:22 PM
jimkelly well, finally got a battery today. hooked it up, ... Oct 10 2013, 01:41 PM
jimkelly hooked my fuel to gas but she backfires and pops. ... Oct 11 2013, 07:24 AM
wndsrfr
hooked my fuel to gas but she backfires and pops.... Oct 11 2013, 07:53 AM
DBCooper
or is this round mark at top of flywheel the tdc ... Oct 11 2013, 09:51 AM
jimkelly firing order seems to be 18436572
but finding tdc ... Oct 11 2013, 08:22 AM
jimkelly thanks guys, you've given me good guidance. dt... Oct 11 2013, 10:36 AM
tooms351 Run a wire with allegator clips from starter selen... Oct 11 2013, 04:40 PM
jimkelly I basically have the with my console - but will tr... Oct 11 2013, 05:52 PM
DBCooper It looks like the number 1 wire goes up to the lef... Oct 11 2013, 04:42 PM
jimkelly all the images i found have cylinders
1-2
3-4
5-6... Oct 11 2013, 05:24 PM
jimkelly db I could kiss you, right on the mouth. GREAT eye... Oct 11 2013, 06:09 PM
Chris H.
Note ... Oct 12 2013, 12:02 PM
jimkelly attached my throttle bracket and throttle cable, a... Oct 14 2013, 08:55 AM
jimkelly set back. fuse box was in contact with block and ... Oct 16 2013, 02:10 PM
Chris H. Whew you dodged a bullet on that one Jim. Check J... Oct 16 2013, 06:35 PM
jimkelly I neglected the first rule - disconnect battery wh... Oct 16 2013, 06:49 PM
bulitt
I neglected the first rule - disconnect battery w... Oct 18 2013, 04:22 PM
jimkelly I thought I may have fried my coil or dist but tha... Oct 18 2013, 04:02 PM
jimkelly price is right.
once this Bacardi wears off, I ca... Oct 18 2013, 04:28 PM
jimkelly yesterday...
filled cooling system with water, spl... Oct 21 2013, 01:32 PM
jimkelly plumbed to carb from firewall, pump and filter.
n... Oct 24 2013, 11:06 AM
jimkelly next to install fuel tank and plug the return line... Oct 24 2013, 03:13 PM
jimkelly got my fuel tank in and fuel pump wired. I need to... Oct 25 2013, 01:31 PM
rhodyguy did you use the jumper wire from the engine relay ... Oct 26 2013, 07:48 AM
jimkelly yes - like this.
http://www.914world.com/bbs2/upl... Oct 26 2013, 07:52 AM
kg6dxn
yes - like this.
As I ponder your symptoms... D... Oct 27 2013, 08:26 PM
rhodyguy the only way to go and still utilize the stock cir... Oct 26 2013, 07:55 AM
jimkelly I could have sworn my car started from key with th... Oct 27 2013, 07:16 AM
Spoke
I still have 2 gremlins, drivers side parking lig... Oct 27 2013, 08:01 AM
jimkelly I will check. I assume you mean both filaments in... Oct 27 2013, 08:36 AM
jimkelly now I am seeing problems everywhere. I pulled a t... Oct 27 2013, 08:29 AM
jimkelly spoke - just tested your directionals rewiring - w... Oct 27 2013, 09:11 AM
jimkelly well - later tach won't do.
it only has one g... Oct 27 2013, 11:21 AM
Spoke Yeah, I didn't like the later tach because of ... Oct 27 2013, 02:53 PM
jimkelly pretty sure its plastic - but I will put it back i... Oct 27 2013, 03:44 PM
jimkelly been off on a tangent with - spoke, dave darling, ... Nov 2 2013, 08:53 AM
jimkelly ok - she started off the ign key and ran for some ... Nov 2 2013, 09:08 AM
kg6dxn You should mount the fuel pump in the front of the... Nov 2 2013, 09:36 AM
rhodyguy rotary pump? if you don't want to do the front... Nov 2 2013, 11:46 AM
jimkelly I checked for a clog or other issue, gas all over ... Nov 2 2013, 02:46 PM
bulitt Obvious Question Jim- do you have gas in the tank? Nov 2 2013, 07:47 PM
jimkelly yes - about 3 gallons - and it spills out if I dis... Nov 3 2013, 06:29 AM
jimkelly dropped ground, but still no good.
put car back o... Nov 4 2013, 01:23 PM
mittelmotor Nice progress. I've heard the pumps are much b... Nov 4 2013, 05:17 PM
jimkelly thanks. lots of pics for those few, that may be l... Nov 4 2013, 07:28 PM
Mike Bellis The Permatex sealant is the best one I've ever... Nov 4 2013, 08:00 PM
DBCooper I've used that stuff since I was a kid. Never... Nov 5 2013, 08:53 AM
jimkelly thanks guys for the comments on the permatex produ... Nov 5 2013, 01:15 PM
jimkelly pump in but will probably relocate fuel filter fur... Nov 7 2013, 11:26 AM
rhodyguy filter pior to the pump? Nov 7 2013, 11:28 AM
jimkelly its after pump. when I had pump higher, I had it ... Nov 7 2013, 11:36 AM
jimkelly i had temporarily removed my rear sway bar so I ca... Nov 8 2013, 12:18 PM
Mike Bellis From the pics, that looks like a very bad pump loc... Nov 8 2013, 08:29 PM
jimkelly I too have smashed my share of hose straps but did... Nov 8 2013, 08:40 PM![]() ![]() |
Lo-Fi Version | Time is now: 12th August 2026 - 04:36 AM |
