> making some progress on my sbc 307 V8 car, -- rear sway bar back in
jimkelly
post Sep 16 2013, 12:45 PM
Delaware USA
wiring my v8
and tell me what I have wrong or missing.
my bad for never labeling the wires (IMG:style_emoticons/default/headbang.gif)
distributor is msd 8360
but you guys are smart (IMG:style_emoticons/default/smoke.gif)
and yes - I better connect that oil guage line or I will have a mess on my hands.
dwillouby
post Sep 17 2013, 06:42 AM
I dont use the relay board. You need a switched 12 v and 12 v starter signal. Installed a 1 wire alt. I am using a MSD / Mallory system with Fast fuel injection. Very simple wiring setup
David
jimkelly   making some progress on my sbc 307 V8 car   Sep 16 2013, 12:45 PM
3d914   IIRC the yellow wire goes to the positive side of ...   Sep 16 2013, 01:01 PM
jimkelly   thank you - I am editing my collage as we go. jim   Sep 16 2013, 01:05 PM
Spoke   Page 5: Red wire from harness is 12V power to coil...   Sep 16 2013, 02:13 PM
jimkelly   spoke I am pretty sure my ignition switch was par...   Sep 16 2013, 02:30 PM
jmmotorsports   spoke I am pretty sure my ignition switch was pa...   Sep 17 2013, 04:15 AM
chads74   spoke I am pretty sure my ignition switch was p...   Sep 17 2013, 06:19 AM
jimkelly   spoke image 6 - the blue wire loops around and co...   Sep 16 2013, 07:31 PM
Spoke   spoke image 6 - the blue wire loops around and c...   Sep 17 2013, 06:49 AM
dwillouby   I dont use the relay board. You need a switched 12...   Sep 17 2013, 06:42 AM
jimkelly   I was thinking that since it seems to be the only ...   Sep 17 2013, 07:03 AM
jimkelly   finally going to put my crimper and heat shrink to...   Sep 17 2013, 08:01 AM
jimkelly   starter, shift linkage, gear oil, coolant fill nec...   Sep 20 2013, 12:45 PM
76-914   Jim, are you doing this and the Suby conversion or...   Sep 20 2013, 02:19 PM
jimkelly   I simply want to get the 1972 V8 running and funct...   Sep 20 2013, 03:24 PM
jimkelly   just goofing around, since I already have a bar th...   Sep 21 2013, 08:34 AM
zambezi   yes they grind better and produce less heat. Easi...   Sep 21 2013, 12:31 PM
jimkelly   engine bay shift rod done : ) 40.75" it is ...   Sep 21 2013, 01:15 PM
jimkelly   some random pics   Sep 22 2013, 11:22 AM
kg6dxn   Your lower spring perch is upside down... :( http...   Sep 22 2013, 07:17 PM
jimkelly   thanks for that!!! jim   Sep 22 2013, 07:45 PM
jimkelly   don't be an idiot like me. anyway, one flippe...   Sep 23 2013, 07:41 AM
76-914   Is that a "red" ground wire? <_<   Sep 23 2013, 03:04 PM
jimkelly   from the relay board to the body? yes. I will ch...   Sep 25 2013, 09:27 AM
jimkelly   also - before, I had the pos from alt running to p...   Sep 25 2013, 09:35 AM
kg6dxn   also - before, I had the pos from alt running to ...   Sep 25 2013, 09:01 PM
jimkelly   mike - I will get those wires buttoned up - thanks...   Sep 26 2013, 09:34 AM
jimkelly   guess i'll run the coolant lines today. the 2...   Sep 29 2013, 08:25 AM
jimkelly   well, not sure I like the relatively short 90 degr...   Sep 29 2013, 03:14 PM
bulitt   I may have to get one of those 90's.   Sep 29 2013, 06:33 PM
jimkelly   since the only electrical connector I have, that h...   Sep 30 2013, 07:32 AM
jimkelly   rcvd the 90 degree tube today - looks good.   Oct 2 2013, 09:18 AM
andys   Much nicer with that aluminum 90! Andys   Oct 2 2013, 09:26 AM
speed metal army   Hey Jim, weather pack electrical connectors are a ...   Oct 2 2013, 10:05 PM
jimkelly   well, my car had a big gap, at top, between the dr...   Oct 7 2013, 11:41 AM
JRust   Yeah the aluminum 90% was a good move. I didn...   Oct 7 2013, 08:11 PM
jimkelly   well two issues. I need to either come up with a ...   Oct 9 2013, 01:12 PM
JRust   The big washer with the groove goes on the bottom ...   Oct 9 2013, 03:17 PM
jimkelly   I have been searching and have yet to find a pic o...   Oct 9 2013, 04:57 PM
JRust   I have been searching and have yet to find a pic ...   Oct 10 2013, 07:20 AM
jimkelly   instead of this jumble of parts, I am thinking of ...   Oct 10 2013, 06:29 AM
bulitt   I'm thinking you will break your trans ears of...   Oct 10 2013, 06:50 AM
jimkelly   for engine mounts, found washers that fit perfectl...   Oct 10 2013, 07:34 AM
Chris H.   Hijack but this exhaust setup is AWESOME That...   Oct 10 2013, 09:43 AM
jimkelly   good point. behind trans is where the most space ...   Oct 10 2013, 09:51 AM
mittelmotor   I like the 2-in/2-out approach as well. Keeps the ...   Oct 10 2013, 01:22 PM
jimkelly   well, finally got a battery today. hooked it up, ...   Oct 10 2013, 01:41 PM
jimkelly   hooked my fuel to gas but she backfires and pops. ...   Oct 11 2013, 07:24 AM
wndsrfr   hooked my fuel to gas but she backfires and pops....   Oct 11 2013, 07:53 AM
DBCooper   or is this round mark at top of flywheel the tdc ...   Oct 11 2013, 09:51 AM
jimkelly   firing order seems to be 18436572 but finding tdc ...   Oct 11 2013, 08:22 AM
jimkelly   thanks guys, you've given me good guidance. dt...   Oct 11 2013, 10:36 AM
tooms351   Run a wire with allegator clips from starter selen...   Oct 11 2013, 04:40 PM
jimkelly   I basically have the with my console - but will tr...   Oct 11 2013, 05:52 PM
DBCooper   It looks like the number 1 wire goes up to the lef...   Oct 11 2013, 04:42 PM
jimkelly   all the images i found have cylinders 1-2 3-4 5-6...   Oct 11 2013, 05:24 PM
jimkelly   db I could kiss you, right on the mouth. GREAT eye...   Oct 11 2013, 06:09 PM
Chris H.   db I could kiss you, right on the mouth. Note ...   Oct 12 2013, 12:02 PM
jimkelly   attached my throttle bracket and throttle cable, a...   Oct 14 2013, 08:55 AM
jimkelly   set back. fuse box was in contact with block and ...   Oct 16 2013, 02:10 PM
Chris H.   Whew you dodged a bullet on that one Jim. Check J...   Oct 16 2013, 06:35 PM
jimkelly   I neglected the first rule - disconnect battery wh...   Oct 16 2013, 06:49 PM
bulitt   I neglected the first rule - disconnect battery w...   Oct 18 2013, 04:22 PM
jimkelly   I thought I may have fried my coil or dist but tha...   Oct 18 2013, 04:02 PM
jimkelly   price is right. once this Bacardi wears off, I ca...   Oct 18 2013, 04:28 PM
jimkelly   yesterday... filled cooling system with water, spl...   Oct 21 2013, 01:32 PM
jimkelly   plumbed to carb from firewall, pump and filter. n...   Oct 24 2013, 11:06 AM
jimkelly   next to install fuel tank and plug the return line...   Oct 24 2013, 03:13 PM
jimkelly   got my fuel tank in and fuel pump wired. I need to...   Oct 25 2013, 01:31 PM
rhodyguy   did you use the jumper wire from the engine relay ...   Oct 26 2013, 07:48 AM
jimkelly   yes - like this. http://www.914world.com/bbs2/upl...   Oct 26 2013, 07:52 AM
kg6dxn   yes - like this. As I ponder your symptoms... D...   Oct 27 2013, 08:26 PM
rhodyguy   the only way to go and still utilize the stock cir...   Oct 26 2013, 07:55 AM
jimkelly   I could have sworn my car started from key with th...   Oct 27 2013, 07:16 AM
Spoke   I still have 2 gremlins, drivers side parking lig...   Oct 27 2013, 08:01 AM
jimkelly   I will check. I assume you mean both filaments in...   Oct 27 2013, 08:36 AM
jimkelly   now I am seeing problems everywhere. I pulled a t...   Oct 27 2013, 08:29 AM
jimkelly   spoke - just tested your directionals rewiring - w...   Oct 27 2013, 09:11 AM
jimkelly   well - later tach won't do. it only has one g...   Oct 27 2013, 11:21 AM
Spoke   Yeah, I didn't like the later tach because of ...   Oct 27 2013, 02:53 PM
jimkelly   pretty sure its plastic - but I will put it back i...   Oct 27 2013, 03:44 PM
jimkelly   been off on a tangent with - spoke, dave darling, ...   Nov 2 2013, 08:53 AM
jimkelly   ok - she started off the ign key and ran for some ...   Nov 2 2013, 09:08 AM
kg6dxn   You should mount the fuel pump in the front of the...   Nov 2 2013, 09:36 AM
rhodyguy   rotary pump? if you don't want to do the front...   Nov 2 2013, 11:46 AM
jimkelly   I checked for a clog or other issue, gas all over ...   Nov 2 2013, 02:46 PM
bulitt   Obvious Question Jim- do you have gas in the tank?   Nov 2 2013, 07:47 PM
jimkelly   yes - about 3 gallons - and it spills out if I dis...   Nov 3 2013, 06:29 AM
jimkelly   dropped ground, but still no good. put car back o...   Nov 4 2013, 01:23 PM
mittelmotor   Nice progress. I've heard the pumps are much b...   Nov 4 2013, 05:17 PM
jimkelly   thanks. lots of pics for those few, that may be l...   Nov 4 2013, 07:28 PM
Mike Bellis   The Permatex sealant is the best one I've ever...   Nov 4 2013, 08:00 PM
DBCooper   I've used that stuff since I was a kid. Never...   Nov 5 2013, 08:53 AM
jimkelly   thanks guys for the comments on the permatex produ...   Nov 5 2013, 01:15 PM
jimkelly   pump in but will probably relocate fuel filter fur...   Nov 7 2013, 11:26 AM
rhodyguy   filter pior to the pump?   Nov 7 2013, 11:28 AM
jimkelly   its after pump. when I had pump higher, I had it ...   Nov 7 2013, 11:36 AM
jimkelly   i had temporarily removed my rear sway bar so I ca...   Nov 8 2013, 12:18 PM
Mike Bellis   From the pics, that looks like a very bad pump loc...   Nov 8 2013, 08:29 PM
jimkelly   I too have smashed my share of hose straps but did...   Nov 8 2013, 08:40 PM
- Lo-Fi Version Time is now: 12th August 2026 - 04:35 AM
