Shifting, 1St gear |
Razorbobsr |
Sep 19 2013, 01:29 PM
Member Group: Members Posts: 282 Joined: 6-June 10 From: Terre Haute Ind Member No.: 11,813 Region Association: Upper MidWest |
I just replaced the bushing in my shifter and the one at the end nearest the tranny, I can get 2/3/4/5 but its a tight fit however I cant get 1st!!!!!!! What did I do wrong? I do get R gear. Bob
rjames |
Sep 20 2013, 02:09 PM
I'm made of metal Group: Members Posts: 3,948 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest |
Can you get into reverse? If not, you may just need to adjust your shifter so that you have more throw towards the left by doing the following:
Put the trans in neutral Clamp the shift rod with something to keep it moving (wrench/vicegrips) Loosen the bolt that that holds the shift rod to the shifter in the tunnel, Keep the shift rod from moving, and move the shifter just a bit to the right. Tighten bolt |
Razorbobsr |
Sep 20 2013, 03:04 PM
Can you get into reverse? If not, you may just need to adjust your shifter so that you have more throw towards the left by doing the following: Put the trans in neutral Clamp the shift rod with something to keep it moving (wrench/vicegrips) Loosen the bolt that that holds the shift rod to the shifter in the tunnel, Keep the shift rod from moving, and move the shifter just a bit to the right. Tighten bolt Yes, I get reverse well. OK, will try that as well. Thanks Bob |
Lo-Fi Version | Time is now: 1st June 2024 - 10:38 PM |
