Opinion on cutting out & steering wheel vibration |
partwerks |
Sep 21 2013, 09:56 PM
Senior Member Group: Members Posts: 1,593 Joined: 7-September 06 From: Grand Island, NE Member No.: 6,787 |
When I put on a new trans ground strap, it definitely made a difference in the starting, and I thought it got rid of the other strange cutting out bug as well?
For at least the last 4 months, it did not act up until this Friday, in about a 15 mile stretch on the Interstate at about 75 mph, it will cut out for about 6 or 7 seconds, and then oddly, take right off again. It did that 3 times. It only tends to do it when going about that speed, (or faster) 2004, WRX. 2.0 Also, I had the mechanic re balance the front tires to see if that was it, and again when going at least 70, it will make the steering wheel quiver. He looked at the front end on the hoist, but could not see anything obvious? It also does it off and on when going at that speed, and not constantly. Any thoughts, ideas, or suggestions on what could be causing it? |
phatnine11 |
Sep 22 2013, 10:39 AM
Member Group: Members Posts: 286 Joined: 22-March 05 From: Rancho Cucamonga, CA Member No.: 3,798 |
Partwerks,
I had the same problem with the cutting out, speed was not factor, it would buck and cutout at any speed. I finally traced it done to the CH sensor. The symptom was the cutting out was getting more frequent. Just an idea and it's the cheapest part to replace. Good luck, Phatnine11 |
Lo-Fi Version | Time is now: 1st June 2024 - 07:02 PM |
