Renn shifter install |
partwerks |
Sep 22 2013, 08:39 AM
Senior Member Group: Members Posts: 1,593 Joined: 7-September 06 From: Grand Island, NE Member No.: 6,787 |
Finally invested in a Renn shifter, and hopefully will put to bed all those shifting woes once and for all!!
Not that my mechanic doesn't know what he is doing, but are there any off the wall issues that might be good to know before we start the project?? I have all new bushings otherwise. |
davesprinkle |
Sep 22 2013, 09:03 AM
Senior Member Group: Members Posts: 720 Joined: 13-October 04 From: Berkeley, CA Member No.: 2,943 Region Association: None |
Get rid of the fore-aft limit stops. Seriously. Take them out and throw them away. The limits should be set by the transmission, not the shifter.
Also, good luck getting the reverse lockout to work. I just took mine out altogether. |
JWest |
Sep 22 2013, 07:56 PM
Senior Member Group: Members Posts: 1,662 Joined: 6-January 03 From: Fort Worth, TX Member No.: 97 Region Association: None |
Get rid of the fore-aft limit stops. Seriously. Take them out and throw them away. The limits should be set by the transmission, not the shifter. You must have adjusted them wrong. Seriously. (IMG:style_emoticons/default/smile.gif) They are for preventing excessive force beyond full engagement in the transmission. If you are not forcing anything, they are never used because they are adjusted with clearance at full engagement. Too many people can't stop themselves from banging gears, it's just a little extra life for the bushings to not be punished so much. Most issues with the shifter come from slop in the bushings or adjustment being off. The RennShift is easier to adjust than the stock shifter, but requires good bushings for full benefit. |
Lo-Fi Version | Time is now: 9th June 2024 - 11:08 AM |
